EDIT: Including the specs on car
M50 Block
M52 Crank
M52 Rods
M52 Pistons
S50 Cams
M52 Exhaust Manifolds
Intake and Exhaust ported (every bit helps)
okay, so this thing won't bloody start...
i have fuel, i have current going to coil and definitely have vacuum.
i checked robertk's thread about the auto tranny switch (pin 65 on ecu) and provided a 12v current and still nothing.
i will attempt to pull the coil pack and actually plug the spark plug into it and then crank to see if spark plug is actually getting current.
it also has the EWS delete chip.
i am almost convinced it is the crank position sensor but haven't tested it yet.
here are two vid's of how it cranks:
anyone have any ideas?
M50 Block
M52 Crank
M52 Rods
M52 Pistons
S50 Cams
