ok now im confused!!!!!!!
  • MDryVur
    • 395
    is there a ews delete chip for the obd2 setup or not?
    do we need to get the stage 2 kit from turner motorsport for it to work.. or is there just a chip...
  • dpgrand
    • 179
    With OBDII you cannot use "chips." Software has to be loaded onto your ECU. So yes, you can delete the EWS from the OBDII setup, but it cannot be done using a "chip." It requires software.
    • MDryVur
      • 395
      so if i have the dme ews ecu and key from the same car do i need to worry about the ews or not...
      • e30polak
        • 6136
        I believe you also need the ring that goes around the ignition cylinder.
        This thread is your friend:
        INSTAGRAM: @UNDR8D_EMPIRE
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          The ring does not have to be from the same VIN, it's just a glorified antenna.
          • MDryVur
            • 395
            thanks polak.. i was looking at that.. lol ...
            • dpgrand
              • 179
              Yes. You are going to have to delete it, or wire it up.
              • MDryVur
                • 395
                im going to be callling thr today and see what they can do with my wiring for the ews...
                • dpgrand
                  • 179
                  Try bimmerworld as well
                  • MDryVur
                    • 395
                    ^ cool thanks for the advise..
                    • 318isbmw
                      • Nov 2005
                      • 2841
                      yeah, I believe bimmerworld, turner and active all can do it. Somewhere there's a thread about deleting it, where they talked about the shops.
                      • Uber E30
                        • 1409
                        I just called THR and talked to John. He said send the ECU to AAW and have them delete the EWS.
                        On a sidenote he is a really nice guy and talked to me for a while about getting my car to pass emissions, what other stuff i would need, and obdI vs obdII. If he will talk to me that much without me paying him anything, i can only imagine how good their support is after i buy the harness.
                        -Alex
                        • MDryVur
                          • 395
                          definately.... he is a really cool guy i talked to him maybe a month ago. i believe he was the owner.. who is AAW ? im googling it now..
                          • Uber E30
                            • 1409
                            Its a link =P
                            -Alex
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              AAW = Active Autowerke
