Massive lifter tick?
  • madjurgen
    • May 2005
    • 1203
    Originally posted by golde30
    EDIT: oh, yer talkin about running with teh VC off....sounds sketchy/
    Whats sketchy about it? Not much different than taking your oil fill lid off while its running. You'll lose vacuum obviously and oil will spray everywhere. But as long as you only do it for a short amount of time, I cant think of any detriments to the motor.
    http://www.pelicanparts.com/bmw/tech...er-Upgrade.htm
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
    • dude8383
      • Jan 2005
      • 10387
      i found something rather interesting.
      since fredk is talking about the notch mating up and all...i realized on realoem the pic is a bit different to the tensioner i have.
      http://www.realoem.com/bmw/diagrams/m/i/20.png
      and mine:
      it doesn't have that notch in it like the one in the pic yet the p/n's match because this is exactly what i ordered from patrick.
      ninja edit:
      i actually upgraded to the s50 tensioner however my m50 came with the older tensioner (two-piece) and there was no notch at the end...
      • dude8383
        • Jan 2005
        • 10387
        found a thread on bimmerforums:
        EDIT: one more but unanswered.
        dude pretty much has a related tensioner issue.
        • golde30
          • 11464
          my s50 one-piece tensioner DOES have the notch for the timing chain rail.
          IG: @Baye30
          • slo325i
            • 417
            Good lord... it sounds exactly like my nissan with a really bad connecting rod after melting the pistons running it too lean...
            '89 325i - Totaled... good bye my love...
            '87 327i budget stroker - SOLD!!!
            '92 240sx - ca18det powered drift toy - SOLD!!!
            '89 325i - coupe - NEW daily
            '96 Audi A6 Quattro- Grocery getter/baby hauler
            '99 Busa - weekend wheelie monster
            • dude8383
              • Jan 2005
              • 10387
              im hoping that isn't the case, but its not something i can't fix.
              yeh mine does too but the rail itself doesn't.
              • dude8383
                • Jan 2005
                • 10387
                i may actually try removing the valve cover but not before i take a look at everything before i actually start it.
                • dude8383
                  • Jan 2005
                  • 10387
                  http://www.pelicanparts.com/bmw/cata...ENGcam_pg3.htm
                  should i perhaps switch to the tensioner that is listed at the top?
                  i will be dropping the oil pan over the weekend and will most likely take of the front timing case cover in the process.
                  i think i will try my luck first and hope that its just the chain tensioner hugely mis-aligned.
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    If your chain rail isn't pre-95(M50 style) and you are using a pre-95 (M50 style) notched tensioner, then you have the wrong tensioner.
                    My 2.9L Build!
                    • golde30
                      • 11464
                      i find that if you order by your motors VIN, then you will always have the rite parts matched up...
                      IG: @Baye30
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        Unless you find out you have a cracked block and have to grab a random one at work that has the least amount of shit on it to get it to the machine shop and don't realize it is an M52 block.
                        haha
                        My 2.9L Build!
                        • dude8383
                          • Jan 2005
                          • 10387
                          haha thats how i ordered my rail guide.
                          haha
                          well like i said above i ordered exactly what came with the motor...but i do see what your saying.
                          so which tensioner should i be ordering then? i want to use the one piece version..
                          • SpecM
                            • Oct 2005
                            • 4531
                            Originally posted by dude8383
                            jeez it will run like that? is that even safe for the motor?
                            not for long its not! Cap off the PCV tube, tho, so it wouldn't suck air into the TB (vacuum leak!), I did this to diag a slack eccentric on my m20
                            1989 cirrisblau-metallic 325i
                            • devonjordan
                              • Jul 2006
                              • 2386
                              That oil pan worked out for you then?...
                              Sorry cant help with the noises...
                              Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
                              Help a brother out, buy your detailing products here...
                              • dude8383
                                • Jan 2005
                                • 10387
                                just got it today!
                                i will install it this weekend and let you know how it goes :)
                                just left ya some feedback btw.
