you dont have to pull the crank though. just the head, and then disonnect the #2 and push the piston/rod through the top.
Massive lifter tick?
haha anything at this point is going to easy for me...i've been hopeful all of this time but theres no point anymore.
im going to first inspect it from the bottom and see just how bad the damage is, maybe a bearing just needs to replaced.
i have a good feeling im going to get the big fuck you on this anyway and will end up taking the head off. i've already mastered removal of the intake manifold. that last 11mm bolt for the manifold is a royal bitch btw.
might as well master everything else then.IG: deniso_nsi Leave me feedback here
Interesting..
I'm curious to see what the end result of this is. Best of luckMikey
-= Epitom3 =-Comment
Fuck it. See how long you can go full throttle until it pops a the rod.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
Maybe you already did this, but if not, pull the coil on #2 while its running just to be sure.
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.Comment
haha do you have a spare motor for me?
i could try but i doubt it will change much...i mean when i put the screwdriver there i heard loud and clear. everywhere else on the block it just wasn't the same.IG: deniso_nsi Leave me feedback here
Who cares if its still moving, its just going along for the ride, it doesnt have thousands of psi exploding inside the combustion chamber anymore. When I spun a rod bearing in my M20, the knock went away when I took away spark to that one cylinder. But what do I know, listen to gold, he obviously knows what he's talking about.
if the knock goes away thats great...but that would still leave me with the problem and running on 5 cylinders hahaWho cares if its still moving, its just going along for the ride, it doesnt have thousands of psi exploding inside the combustion chamber anymore. When I spun a rod bearing in my M20, the knock went away when I took away spark to that one cylinder. But what do I know, listen to gold, he obviously knows what he's talking about.IG: deniso_nsi Leave me feedback here
My suggestion was purely for correct diagnosis before you go tearing things apart.
you guys won't believe this...but it isn't the rod.
The rods are hitting the freaking oil pan baffle (e36)...i don't know how its possible but somehow they are.
I have the E34 baffle at home and im thinking about using that one instead because it sits a bit farther away.
I checked for play in ALL of the rods and there is no play. I'm kind of shocked and delighted.
What do you guys think? E34 baffle?Last edited by dude8383; 09-14-2010, 06:20 AM.IG: deniso_nsi Leave me feedback here
