my first time seeing this.
Turner obd1 water temp sensor adapter
So Doug said it works, then Ian proved it does not work.... yet someone made his own adapter and it worked?http://www.r3vlimited.com/board/show...7&postcount=25
They have stated this multiple times. I guess we're all just a bunch of tards.
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
i think that link is for obd1 conversion in an e36So Doug said it works, then Ian proved it does not work.... yet someone made his own adapter and it worked?
http://homepage.mac.com/aceves/OBDI/OBD_ONE3.htm______________________
ex-Chief Operating Officer
Blunt Tech Industries
West Coast and Pacific RimComment
Yep it is. I don't understand why TMS doesn't admit that it does not work ....Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
No call back...
:down:
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.Comment
So why can you not just clip the brown wire with red stripe and run the single wire plug off the old E30 harness to the E30 sensor? That's how we wired mine, haven't started yet but in theory no reason it should not work.:nice:Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
