Can I run two exhaust cams?
  • DeeJayDubbuyew
    • Jul 2008
    • 56
    I'm doing a head gasket swap on a '92 m50 (non-vanos) & the intake cam has some rust on the lobes from setting for awhile. I have a spare motor just like it on the stand & considered using the cam out of it - except it has the same problem. Could I use the exhaust cam out of the spare motor? Two exhaust cams?
    I've heard of people switching cams when purchasing only one aftermarket cam & just wondered if anyone knew for sure about such things.
    Thanks in advance for any helpful advice.
    Oh, & I know, use the "search" button! :)
    DJW
  • Rolla1990
    • 199
    I don't think it will work.
    Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
    • SamE30e
      • Sep 2007
      • 4319
      It would work. But it wouldn't run very well.
      1985 325e 2.8 Turbo VEMS
      • DeeJayDubbuyew
        • Jul 2008
        • 56
        after searching a little, I see some folks recommend running your intake on the exhaust side with an aftermarket intake, but not what I'm considering.
        maybe the rust will come off with some 400 grit & oil...
        DJW
        • Aptyp
          • 6584
          400? try 1600, safer
          • hoveringuy
            • Dec 2005
            • 2743
            Scotch pad and WD-40. It's only surface corrosion.
            I made the mistake of pressure washing my valve cover and placing it over the cams when I thought it was dry. It wasn't. I had nasty looking surface corrosion in a few hours that went away just as quickly.
            • E30Idea
              • Mar 2007
              • 2196
              Exactly. DO NOT USE SANDPAPER!!!! ANY GRIT!!!!
              ** Lot's of M20 turbo parts for sale.**
              Turn key track car.
              http://www.r3vlimited.com/board/showthread.php?t=222066
              • dpgrand
                • 179
                This is true, but you should not run two exhaust cams.
                And please don't use sandpaper.
                • DeeJayDubbuyew
                  • Jul 2008
                  • 56
                  scotch pad and wd-40. It's only surface corrosion.
                  Originally posted by e30idea
                  exactly. Do not use sandpaper!!!! Any grit!!!!
                  Yeah, good thinkin' - I've also got a wire brush with brass bristles I may try.
                  DJW
                  • 416stroker
                    • May 2008
                    • 2448
                    You should use crocus cloth..I believe 3m makes it
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • SpecM
                      • Oct 2005
                      • 4531
                      I say wd-40 and a soft rag. The surface rust will come off once the engine is ran the first time.
                      Just change the oil afterwards
                      1989 cirrisblau-metallic 325i
                      • JGood
                        • Jan 2004
                        • 7959
                        Agreed. With any bristle brush or gritty cleaner, you run the risk of creating scratches... And with scratches you get peaks and valleys, where cracks start and/or uneven wear occurs.
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • So Live
                          • 2512
                          Run two intake cams!
                          -Chris
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            Or one NV intake cam and an S50/S52 exhaust cam.
                            My 2.9L Build!
                            • SpecM
                              • Oct 2005
                              • 4531
                              this is the magic recipe
