The dreaded no start............
  • whysimon
    • Jan 2007
    • 663
    any more idea's?????
    STILL NO START
    • SpecM
      • Oct 2005
      • 4531
      Originally posted by whysimon
      I originally thought it could be the lifters so I took the plugs out and put .5 of a straw's amount of oil down the cylinder.
      what does this have to do with the lifters?
      anyway, it sounds like you have all the needed stuff for a running engine...
      what is the CPS reading, @ the DME harness? (in ohms)
      1989 cirrisblau-metallic 325i
      • whysimon
        • Jan 2007
        • 663
        has anyone ever conducted a noid test??? Did it prove valuable??
        Thanks
        • 88E30M50
          • Apr 2008
          • 48
          Thanks
          I did a noid test using a set of noid lights to confirm injector pulse. It worked for that.
          Tim
          Indianapolis, IN, USA
          88 325is (M50)
          92 525iT (5 speed)
          98 328is
          2011 535is
          69 Fiat Spider
          68 Fiat Spider (122nd chassis built for the US)
          • kylebes1
            • May 2004
            • 2804
            I bought the turner adapter. Although, I bought a "blue" temp sensor to directly plug into the head, therefore eliminating the Turner adapter.
            You need to have at least the DME coolant temp sensor attached... not sure what adapter you are talking about. if you plugged in the one for the cluster and not the DME switch them and see what happens...
            • whysimon
              • Jan 2007
              • 663
              I think I've narrowed down the problem. I think its the injectors. Damn Euro Depot! I'll let you guys know in the morning.
              Thanks for everything
              • whysimon
                • Jan 2007
                • 663
                alright, after countless hours of troubleshooting; I've narrowed down the problem. There's no signal to tell the injectors to open and close. The injectors are grounded, the DME is grounded, and the relay is getting power and is also grounded. Where do I go from here???
                • whysimon
                  • Jan 2007
                  • 663
                  does anyone have a diagram of the X20 plug? I need the e36 side and the e30 side to double check my pins. My car is 11/86 "E" model
                  • OoPEZoO
                    • Jan 2007
                    • 83
                    Long shot here, but.......start reading at post #57
