Stock fuel pump getting tired... Go Walbro?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Originally posted by DCColegrove
    I 'dunno'... Did you?
    'Gotta' remember... I'm an old man... Memory is fading.
    Yes, but it was IRL w/ kronus in my garage.
    • OrganicMechanic
      • Jan 2008
      • 1719
      I replaced my FPwith a walbro. I love it I know that it will not have any issues with keeping up.
      join the E30 Cabrio owners gruppe
      click here for details
      • etxxz
        • Feb 2006
        • 2085
        i rock an intank walbro 255. you need to replace the fuel lines with higher pressure ones. I kept blowing the feed lines (4 lines total) with regular hose. I used marine 200psi hosing and caled it a day. My Walbro is rated 84psi at the lowest flow rate.
        quiet, gots about 8k miles on it, works 100%. paid $60 for it on craigslist. screw oem.
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
          • 37832
          ^ Any idea which model number pump I need?
          Also, what's the cost on the Bosch 044 pump?
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • matt
            • 3731
            Real 044s are about 3x as much as Walbros. Beware imitations...
            • etxxz
              • Feb 2006
              • 2085
              ebay. in-tank. search under bmw that's it. All the 255 have the same flow vs pressure curve pretty much its a differece in package size, cross flow/straight flow (S.F. is what u want). You can really mount any of these pumps on the stock e30 pump/sump. beware of stock fuel lines.
              91 BMW 325i [sold]
              • matt
                • 3731
                If you're having fuel line issues, your pressure is too high. Probably because your FPR can't bypass enough fuel for your "upgraded" pump.
                • mentaleeill
                  • 850
                  Originally posted by e30 Luv
                  Can you give some more info on this?
                  use a 4 pin 30 amp relay. 1 pin gets 12volt from battery, 1 gets grounded, 1 is switch ed power in(factory pump power) and the other goes to + on pump.
                  • dude8383
                    • Jan 2005
                    • 10387
                    That noise could be caused by a bad transfer pump (little bastard in the tank)
                    ...Could also be an FPR issue?
                    MR 325... Is the pump you are talking about the one that's all over eBay?
                    the transfer pump sits in the tank with the fuel level sender right? isn't this the fuel pump? i may not be familiar with the term "transfer pump" ...so if the two are really the same thing let me know!
                    mine hisses like a mother fucker but its a brand new fuel pump
                    • kronus
                      • Apr 2008
                      • 13032
                      I have an early model e30. They have two fuel pumps, the first one in the tank is a transfer pump and sits together with the fuel level sender. Then, there's an inline pump next to the fuel filter in front of the rear driver wheel well.
                      cars beep boop
                      • 0000000000
                        • 473
                        My walbro works fine. knock on wood
                        • dude8383
                          • Jan 2005
                          • 10387
                          ah bit different on the 318is'
                          • e30 Luv
                            • Dec 2006
                            • 395
                            Like this?
                            What about the ground on the fuel pump? and the negative on the plug?
                            • kronus
                              • Apr 2008
                              • 13032
                              I think you're going to want battery + to go to pin 3 on that relay, and power in to pin 2. That circuit doesn't make sense otherwise.
                              cars beep boop
                              • e30 Luv
                                • Dec 2006
                                • 395
                                Gotcha, thanks.
