Solid lifters
  • e30this
    • 3580
    Solid lifters
    What are the advantages to solid lifters??
    I seen them listed on the TMS site but I have only ever heard of one person using them.
  • terrytinney
    • 9
    The stock hydraulic lifters tend to collapse especially at sustained high RPMs and will clatter and not open the valves all the way. The drawback with solid lifters is you have to use different cams with clearance ramps designed for use with solid lifters and you have to set and occasionally re-adjust the valve lash, which involves removing the cams and changing lash caps. The benefit is you can run a much more aggressive cam without having to go too much stiffer on the valve springs because the solid lifters are usually much lighter than hydraulics.
    Terry Tinney
    Performance Motors
    terrytinney.com
    • e30s52
      • Oct 2007
      • 5235
      Solid lifters are alot more noise too but if your going to sunbelt cams I would get solid lifters.
      www.gutenparts.com
      • 318isbmw
        • Nov 2005
        • 2843
        They can put more wear on the drivetrain, but for a more aggressive cam setup, can be a smarter decision for high rpm's like the others said.
        • golde30
          • 11464
          welcome to r3v Terry. hopefully you can navigate through all the clutter and crap on this site!
          IG: @Baye30
          • kenika65
            • Aug 2007
            • 1336
            Id only use if you plan on racing the car,,, Never would I use sold lifter on a street car, well except for in my 289 in my 65 stang...
            1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
            1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
            • windnsea00
              • 158
              Hmm, so would the S14, S38, Euro S50B30/B32, and S54 not be good street car engines...
              Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
              • kenika65
                • Aug 2007
                • 1336
                Hello they are built that way from the factory not thrown together at your house...
                • DCColegrove
                  • 2748
                  They weigh less and they don't "pump up" or collapse.
