Which is Better - Standard ecu or aftermarket management
  • Mohammed_A
    • 344
    Gonna be busy with a s50b32 swap soon and just gathering the required parts/stuff etc. I have a question, which is better, standard ecu or aftermarket management? (go tech, dicktator, etc).??????
  • JGood
    • Jan 2004
    • 7959
    What do you mean by "better"? Obviously you have more tuning capability with a standalone, or even a piggyback, but it's more expensive and obviously you have the hassle of tuning.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • 2002maniac
      • 4260
      dick tater sounds interesting... But unless you have a pro to dyno tune it for you, i doubt you'd end up any better off than with the stock ecu.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        NA stay stock, turbo, superchargers, ITB's, etc, go standalone.
        • e30polak
          • 6136
          He's got itbs with that s50b32. ;)
          And unless you plan on doing cams and other NA motor mods, I'd say keep the stock ecu. Plus, can those other standalone ecus handle vanos, let alone dual vanos???
          INSTAGRAM: @UNDR8D_EMPIRE
          • matt
            • 3731
            The stock ECU is more powerful than most any standalone (especially on euro motors) it's just harder to tune.
            I can help you guys in the US with that, even for turbos/standalone/supercharger... Stock ECU all the way.
            • Mike B.
              • Jan 2006
              • 987
              I have someone that can provide a group N flash for the euro DME's (along with an EWS-II delete).
              • Mohammed_A
                • 344
                The problem im having here in south africa is there are not mny guys that can do the ews delete and so on,especially that this motor runs on the siemens ecu, they can do it but have too many problems after. The other alternative is to change the cams,cam box and vanos as well as entire engine harness to the s50b30 which does not have any problem running here , but that a whole expense on its own. The management i quoted above does have vanos control and there are plenty of guys who can set it up so i was just wondering if it would be better and easier to just trash the stock ecu and harness and go with the management
                • e30polak
                  • 6136
                  Well it sounds like staying stock will be a bigger hassle. If the management system is competent, and you have good tuners out there, then you should be fine.
                  • Mike B.
                    • Jan 2006
                    • 987
                    What is holding you back from keeping the stock DME, just EWS? If so, it's pretty easy to wire it up so it works as long as you have the right componants.
                    • gobuffs
                      • Dec 2004
                      • 513
                      I have no issues with the S50B32 in my E30....EWS works fine.
                      Ok...I do have one issue that I am still trying to figure out, but the motor runs fine (the only evidence of an issue is on the dyno).
                      • Mohammed_A
                        • 344
                        for now im just listening to people who have done it before,something about the transponder on the key and stuff..... please tell me what are the right components bearing in mind this motor has a siemens ecu and double vanos
                        • Mohammed_A
                          • 344
                          but how i dont understand, are u using the e36 key and stuff
                          • Mike B.
                            • Jan 2006
                            • 987
                            The componants that talk to one another are the EWS box (gray w/ yellow top), key, and DME. If you have all of those componants that came with the car you are fine. You also need a RF transmit/receive box and the RF antenna ring. These are not specific and can be purchased any where.
                            A good wiring diagram for the setup is as follows:
                            If you have a key, EWS box and DME from different cars, you can send them out to be reprogrammed to speak to one another. I have a source for this if you are interested.
                            • gobuffs
                              • Dec 2004
                              • 513
                              Yes I have the E36 key.
                              Huh, mine is wired differently than that picture. Mine is wired as follows:
                              Grey box
                              -EWS 1 (black/yellow) to X20 connector #18
                              -EWS 2 (small white/purple) to X20 #17 (this is the diagnostic port- not required but needed to diagnose any EWS issues)
                              -ignition tumbler position 3 to EWS pin 3 (big black/green)
                              -EWS 4 (green) to X20 #7
                              -EWS 5 (red/yellow) to +12V power
                              -EWS 7 (brown) to ground
                              -EWS 12 (black) to X20 #20
                              -EWS 13 (light blue) to EWS transmit box wire #1 (blue)
                              -IF USING a auto tranny EWS system- you might need to connect EWS 9 to +12V power.
                              EWS transmit box
                              -1 to EWS 13
                              -2 to +12V power
                              -3 to ground
                              other connector to antenna (key relationship to antenna IS important to a certain extent). If you have everything EWS working right, you should hear the grey EWS box "click" (like a relay closing) if you have proper alignment of the key.
                              Is the EWS box specific? I.e. is it programmed? I thought the only thing programmed was the DME. I thought the EWS box just transmitted between the smaller box and the DME? I thought the signal from the antenna (that read the key info) was sent to the EWS box them to the DME and then the DME returns a signal to EWS box if the signal was right. I have a BMW file that talks about the different EWS systems at home, I'll have to reread it.
