Problem with an M roadster
  • e30s52
    • Oct 2007
    • 5235
    So my friends car is throwing a check engine light. Each time it does it is a quart low. He just drove 1200 miles and it threw a check light. pulled the dip stick and it was a quart low. He filled it up and 10mins later throws another check light. Its not leaking at all from anywhere that I can see. Any one have an idea of what it could be?
    thanks
    alex
    www.gutenparts.com
  • kronus
    • Apr 2008
    • 13028
    Well... if it loses a quart of oil in 10 minutes, it's leaking oil. That stuff doesn't just evaporate. Look harder.
    cars beep boop
    • VacMan
      • Apr 2007
      • 2405
      Are you putting oil into the right spot? Sounds like you're filling the wrong hole.
      • e30s52
        • Oct 2007
        • 5235
        Its the right hole lol. I havent look its my friend who is looking.
        www.gutenparts.com
        • e30s52
          • Oct 2007
          • 5235
          sorry it wasnt 10mins it was 1200 miles and then it was a quart low.
          www.gutenparts.com
          • Danny
            • 14216
            That's a big difference.
            • hoveringuy
              • Dec 2005
              • 2700
              He drives REALLY fast!
              • e30s52
                • Oct 2007
                • 5235
                ok... Anything that helps out now?
                www.gutenparts.com
                • hugh jass
                  • 2220
                  has anyone been underneath to see if its wet under the car? how many miles are on the motor?
                  ______________________
                  ex-Chief Operating Officer
                  Blunt Tech Industries
                  West Coast and Pacific Rim
                  • e30s52
                    • Oct 2007
                    • 5235
                    Tons of water thats it. 60,000 on the motor. The water has no oil in it ethier.
                    www.gutenparts.com
                    • matt
                      • 3731
                      You should scan it. It will tell you whats wrong.
                      And scan it with a peake or something BMW specific, not a freaking generic OBDII tool.
                      • e30s52
                        • Oct 2007
                        • 5235
                        Thats next on my list to buy. All I have right now is a genises.
                        www.gutenparts.com
                        • Thor
                          • Jan 2008
                          • 31
                          Are you part of a local BMW CCA group? I'd be willing to guess someone there would have a Peake reader.
                          • E30 Memorial
                            • Jan 2005
                            • 315
                            You're welcome to stop by and use my Peake if needed. I'm in the Wallingford/Greenlake area.
                            PSR BMWCCA member #346561
                            Steve
                            '89 332i
                            '90 M3
                            '01 530is
                            '24 MC JCW
                            '13 ZL1 Camaro
                            '18 RAM 3500
                            • e30s52
                              • Oct 2007
                              • 5235
                              Thanks I will let You know.
                              www.gutenparts.com
