Where do these wires go?
  • logger
    • Mar 2007
    • 385
    Originally posted by Fidhle007
    Wait, don't you own a big machine shop? Why is this so hard for you?
    Oh because I am a machinist I make tools. I am not or even close to a mechanic.
    Thanks though!
    sigpic I HATE SPEED BUMPS !!!!!
    • logger
      • Mar 2007
      • 385
      Originally posted by jakeb
      no crank = no fuel pump. It might prime but it will not just run when the key is in the on pos.
      OK so if I start cranking it over fuel should poor out ?
      • FredK
        • 14759
        Yes, if you've hooked things up correctly, the fuel should come out of the supply line.
        I am fairly certain that you have an E34 harness there. The wire color can be determined by using a razor and scoring the heat shrink tubing next to each ring terminal. Brown = ground, red = power (12V).
        • logger
          • Mar 2007
          • 385
          Ok then I have 1 red 1 blk witch are hooked up corectly. Then there is 5brown and 1 brn/blk that all go to the same connector these I have grounded as well. When I tried to find out what was fuel in and fuel return by turning to ON position nothing happened but I will see tomorrow if cranking it over works.
          • BDSax
            Junkyard King
            • Mar 2006
            • 3593
            Fred,
            Green is ground, White is Neutral, and Black is Hot
            NEED SOME VINYL STICKERS???
            • FredK
              • 14759
              Did you hear the fuel pump buzz when you turned the car to the on position?
              • FredK
                • 14759
                Originally posted by BDSax
                Fred,
                Yes, that's National Electrical Code for 120VAC. :p Let's not confuse logger, though. :mrgreen:
                • BDSax
                  Junkyard King
                  • Mar 2006
                  • 3593
                  LOL
                  im studying for my Florida EC EXAM! YAY!
                  • logger
                    • Mar 2007
                    • 385
                    Did not check but should it? With out cranking it?
                    • BDSax
                      Junkyard King
                      • Mar 2006
                      • 3593
                      it should buzz with you turn the key. how are your relays?
                      • logger
                        • Mar 2007
                        • 385
                        Fine I think? I will check for buzzing tomorrow. Will the m42 relays be the same?
                        • logger
                          • Mar 2007
                          • 385
                          No fuel
                          Ok still no fuel checked all power and grounds.
                          There is no power @ fuse #11.
                          There is no power @ my adapter green/purple wire.
                          There is no power @ fuel pump itself.
                          I have tried turning the engine over.
                          What else can I check?
                          • logger
                            • Mar 2007
                            • 385
                            Ok now there is power at the relay but not going through it. I guess? I can use a small piece of wire to jump it and the fuel pump comes on. Is the relay shit?
                            • madjurgen
                              • May 2005
                              • 1203
                              Sounds like your DME isnt grounded.
                              As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                              You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                              • logger
                                • Mar 2007
                                • 385
                                I think it is. Can some one tell me the fuel relay part#. I phoned bmw and the guy I spoke to said he thinks it is a pink one??? But is not sure.
