my throttle body has a second butterfly upstream of the main one that bolts to the intake manifold. obviously, i have no plans to use that system and it seems a bit in the way. if i were to remove it(it will unbolt) there won't be any flange for the intake boot to mount. what would be my best course of action?
my s52 has traction control. how do i get rid of it?
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackTags: None
There should still be a flange for the boot to mount to...
You will need the non-ASC boot, and depending on the routing and connectors of the vacuum hoses that go into the ASC throttle body and/or boot, you may need to replace/modify them. I'm not too familiar with m52's, so I'm not sure. With an m50, you just unbolt the ASC throttle body, put the new boot on, and connect everything back up.
Originally posted by e30s52 View PostDid you get any more traction with it on?
has anyone tried the throttle body from a 540 or 740? would it even fit the manifold? saw one in the junkyard yesterday and that got me thinking....sigpic
Gigitty Gigitty!!!!
