Electric Fan Mounting E30 325i & E30 318is - With A/C
  • dude8383
    • Jan 2005
    • 10387
    I posted this in the M20 section but I'm not getting any answers and since this is for 24V application, might as well post here too.
    I am currently using the E30 318is (m42) radiator and I can't fit my 16" (2.05" thick) fan because it rubs pretty hard against the A/C belt tensioner.
    I'm trying to get measurements for the E30 325i radiator and so far I have:
    21.375" core width
    17" core height
    1.3125" thickness
    On Nissens site:
    550mm core width ~ 21.654"
    439mm core height ~ 17.283"
    32mm thickness ~ 1.260"
    Pics from site below:
    E30 - 325i
    E30 - 318i
    If you could post pictures of the way your fan is mounted I would really appreciate it...
    The way I see it from the pics, I think the guys running the 325i radiator are pushing the fan as far left as possible so that it doesn't come into contact with the tensioner. I just can't find any pictures here though.
    Thank you very much guys!
  • WhatWentWong
    • Jun 2008
    • 265
    Just curious....does anybody run NO fan, and just use the A/C aux fan?
    • ethirtydavid
      • Jan 2008
      • 2331
      yes, it's called the mechanical fan delete. very worthwhile mod. search forums - there are a couple things you need to get
      • jahnaboi
        • Oct 2006
        • 1742
        I've ran almost 800 miles on my s52 with no mechanical fan, just using my stock a/c aux fan. I didn't touch any wiring for the fan at all. I have no a/c compressor right now as I will make custom lines to fit the compressor. To tell you the truth when my temp goes up close to half way I just push the a/c button and the fan comes on till the temp gets right before the 1/4 mark and shuts off. If I don't toggle the switch at half and my temp gets to 3/4 mark, the high speed of the aux fan turns on all by itself (without pushing the a/c button). So basically no bad things with no mechanical fan. I do plan on getting a better cfm fan and making a custom shroud between the a/c condenser and the radiator and also change the fan switch temp sensor to a lower degree one.
        -Jasper
        SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
        • russiane30
          • Dec 2008
          • 46
          im running a 14" fan right between a bumper and ac condensor works perfect for me
          • dude8383
            • Jan 2005
            • 10387
            post pics if you can please.
            • dude8383
              • Jan 2005
              • 10387
              is no one running a/c with their swaps???
              • dude8383
                • Jan 2005
                • 10387
                what do you guys think about mounting a big and powerful fan instead of the aux fan?
                i know that the unit is pretty stout, just wondering if there is something better.
                  • 34835
                  the stock fan works fine, it's just loud and draws a lot of power. a newer more efficient fan is going to flow more while being quieter and drawing less amps. they will also likely be a lb or two lighter. look for an S-blade fan for something quiet and efficient. Also a 16" fan will *just* fit behind the bumper.
                  • Beej '86 325es
                    • 2639
                    -Brandon
                    '86 325es S50
                    '12 VW GTI Autobahn DSG
                    '03 540i M-Sport (sold)
                    '08 Jeep SRT-8 (sold)
                    For sale:
                    S50 TMS chip for Schricks
                    • kishg
                      • Sep 2006
                      • 2624
                      Originally posted by Beej '86 325es
                      wow.. no radiator even, just fan eh.. impressed :)
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • Beej '86 325es
                        • 2639
                        Notice I opted not to install the engine either. The car is slow, but it saves gas.
                        -Brandon
                        '86 325es S50
                        For sale:
                        • Keanan
                          • May 2007
                          • 88
                          Everyone is doing the engine delete now a days.
                          What will the next fad be? Brain delete? or maybe that was what started it all.
                          • Beej '86 325es
                            • 2639
                            That was attempt at humor...because there's obviously not an engine in the car. ;)
                            -Brandon
                            '86 325es S50
                            For sale:
                            • Keanan
                              • May 2007
                              • 88
                              My attempt at humor was in response to your attempt at humor. I'll keep trying, maybe some day I will be a comedian.
                              Hey what kind of mileage do you get without an engine? I would think it would be pretty good.
