I guess it's that time for a 24v swap thread
  • BenM
    • 2184
    #91
    Crank should be around 600
    Cam should be around 1500
    At least those are the specs for the M42. M50 should be similar.
    I think...
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • SamE30e
      • Sep 2007
      • 4319
      #92
      Friend with a bently just told it it should be 1280ohms across terminals 1 and 2 I got 468.
      1985 325e 2.8 Turbo VEMS
      • FredK
        • 14761
        #93
        The Bentley is wrong. The CPS should have a resistance of around 500 ohms. Most people get around 540 ohms.
        • logger
          • Mar 2007
          • 385
          #94
          I get 480ohms across my cps. Your fuel pump relay is 1 of the 3 on the harness I think the middle one. Try to jump that. My car would not start at first no fuel no spark turned out to be the ecm I bought had no chip in it. You could check that as well.
          sigpic I HATE SPEED BUMPS !!!!!
          • SamE30e
            • Sep 2007
            • 4319
            #95
            You guys fucking serious!??!?! FUCK
            That could temporarily solve the fuel problem, but not the spark.
            • SamE30e
              • Sep 2007
              • 4319
              #96
              Ok, so lets see what the engine needs to run
              Fuel and Spark - Not there
              Why wouldn't it have fuel and spark
              Crank position sensor
              Cam Position sensor
              MAF
              ECU
              Am I missing anything?
              • logger
                • Mar 2007
                • 385
                #97
                Do you have the ground/power wires from the wiring harness close to the ecm hooked up? And hooked up right?
                • SamE30e
                  • Sep 2007
                  • 4319
                  #98
                  There are the two on the diagnostic plug. Are they both grounds?
                  Theres also that stray wire on the X20 side that I was told I didn't have to hook up.
                  • logger
                    • Mar 2007
                    • 385
                    #99
                    OH I think I have a different harness than you mine has 2 grounds and 1 power close to the ecu.
                    • SamE30e
                      • Sep 2007
                      • 4319
                      #100
                      I have a E36 harness non vanos. I have a big red wire that is suposed to goto the E36 fusebox.
                      Then on the passenger side of the harness there is 3 wires, one power that comes off the starter then 2 wires off the diagnostic port harness (those are what i'm unsure about)
                      • SamE30e
                        • Sep 2007
                        • 4319
                        #101
                        IT'S ALIVEEEE!!!
                        Stupid mistake.. Again. Didn't hook up the relay power wire on the diagnostic port harness. Hooked it up, all the relays clicked, and fired right up.
                        • pilotskillse30
                          • Dec 2006
                          • 1957
                          #102
                          this wiring stuff is giving me a headache...will this cure it...its the adapter AKG motorsports sells
                          I'm installing a 95 m3 motor, harness, tranny, and ecu...if I install the entire m3 harness I wont need this adapter correct..this is only if I keep the original e30 harness right
                          • SamE30e
                            • Sep 2007
                            • 4319
                            #103
                            haha, that wiring was a joke, I don't know why people would even spend 200+$ on that!
                            Don't be afraid of wiring, it's nothing, theres enough info around to figure it out.
                            Video of it running http://tinypic.com/player.php?v=9u5izc&s=5
                            • pilotskillse30
                              • Dec 2006
                              • 1957
                              #104
                              I also ordered that ORCA cd..did I go the wrong way there to....and to the previous question
                              ""I'm installing a 95 m3 motor, harness, tranny, and ecu...if I install the entire m3 harness I wont need this adapter correct..this is only if I keep the original e30 harness right""
                              • SamE30e
                                • Sep 2007
                                • 4319
                                #105
                                Orca is a good thing to have. The C101 connector basically connects inside the car, to the engine. Unless you play on swapping EVERYTHING from the M3 over, when I say everything, I mean EVERYTHING, which includes the dash harness.
                                You'll need that connector, it's not a big deal at all, it's actually a minor thing in the swap.
