wiring troubles.
  • xLegendOZWest
    • Jan 2009
    • 406
    for real = O ohhh nooo! does anyone think it would work without it? or maybe hard wired to the chassis if its just like rpm and power signals?
    Live Fast. Drive Faster.
    "Nitrous is like a hot girl with an STD... :)
    You wanna hit it, but your afraid of the consequences :(
    • xLegendOZWest
      • Jan 2009
      • 406
      so i looked at the etm listed above and i cant figure out what wires do what on the m50 auto plug!! help!!!!!
      • xLegendOZWest
        • Jan 2009
        • 406
        okay. so new problem. (other then not knowing how to wire my tranny!) after I pulled the motor my windows stopped working (wanted to roll em up so I can lay my tint) and they no work! is part of the engine harness have the connectors for the windows? because there were like 3 connectors in the glovebox ith the ecu. and I thought one of the relays were for the windows in the fuse block. thanks
        • FredK
          • 14745
          It is because your unloader relays are not grounded through the starter, because the starter has been removed. Here is a post I made a little over a year ago about this exact subject:
          • xLegendOZWest
            • Jan 2009
            • 406
            Your the man!
            • xLegendOZWest
              • Jan 2009
              • 406
              okay. so I tried this same thing. I grounded pin 15 through tab 85 on k7 and one window went up and then it stopped working. do I need to use k5 as well as k7?
              • FredK
                • 14745
                You can ground K5 and K7 by running a wire from pin 15 of the C101 to chassis ground. Turn the key to ON, roll up the windows, and call it a day. The power windows are powered through fuse 17, which is powered through K5.
