Problem after swap
  • logger
    • Mar 2007
    • 385
    Problem after swap
    Runs great but now power windows and heater fan are out no fuses blown where is the relay?
    sigpic I HATE SPEED BUMPS !!!!!
  • FredK
    • 14762
    What starter did you use?
    It sounds like your K5/K7 relays aren't being triggered properly. These unloader relays are supposed to interrupt the function of the power windows and blower motor during start and start only.
    • logger
      • Mar 2007
      • 385
      Used the m52 starter that came with the engine. The windows and fan worked for a while though?
      • ZiMMie
        • Jun 2004
        • 968
        do a search on the Unloader Relay as suggest above.
        www.stancefactory.com
        • logger
          • Mar 2007
          • 385
          Where is this relay?
          • logger
            • Mar 2007
            • 385
            Oh right k5 k7 ok will check thanks.
            • ZiMMie
              • Jun 2004
              • 968
              its not the relay,
              its ur wiring to trigger the relay something its not right double chk the wiring on the round plug.
              • hoveringuy
                • Dec 2005
                • 2744
                its not the relay,
                Agree. Relay is probably fine. You've somehow put it in a permanent state of "unloaded". Pin 15, black/green wire. Check voltage on that.
