Raceland eBay headers??
  • JeffRR
    • 277
    #46
    SS rep pics.
    I couldn't get a good shot of the clearance to the subframe, but these should give you an idea of the other tight areas.
    • z31maniac
      • 17566
      #47
      Thanks for posting up those pictures, I appreciate it.
      www.gutenparts.com
      • JeffRR
        • 277
        #48
        Hope it helps.
        I forgot to mention this before, but I did take down some of the mounting arm where is was contacting the header tube.
        • Mr Two
          • Jul 2008
          • 590
          #49
          Weee! I can barely pull on e92 M3s now :)
          • e30polak
            • 6136
            #50
            Originally posted by Mr Two
            http://www.youtube.com/watch?v=QwJLg4vZRmc
            That thing sounds great! It pulls really nice too! :D
            Scarlet's fat ass needs to lose some weight...
            INSTAGRAM: @UNDR8D_EMPIRE
            • z31maniac
              • 17566
              #51
              Sounds good!
              www.gutenparts.com
              • hoveringuy
                • Dec 2005
                • 2745
                #52
                I've been reading this thread with interest and since I love bloodied knuckles and weld slag burning through my shirt I'm thinking that long tube headers might be my cup of tea.
                This would replace OBD2 manifolds--->OBD2 mid section on my M54.
                I've had to do all of the previously mentioned massaging on my mid pipe to make it clear the e30 obstacle course to the headers. I'm really game to do it again. NOT!
                So, how restrictive are the OBD2 headers compared to the long tube headers? If I'm going to do this I'd like to get a better idea of before/after power. Anybody have dyno data to support your butt data?
                • surebimmer
                  • Jan 2004
                  • 978
                  #53
                  Here are the pictures of the spacer that my dad made with his buddy's mill.
                  And the clearance that this spacer made. Before this spacer sway bar hit the header.
                  • Mr Two
                    • Jul 2008
                    • 590
                    #54
                    Can you post a more detailed pic showing what you did with the "tab" end of the plate?
                    • z31maniac
                      • 17566
                      #55
                      Hmmm, the new UUC stuff does end up pushing the sway bar down a bit, how thick is that spacer?
                      www.gutenparts.com
                      • BMW_TUNER
                        • Jul 2006
                        • 1386
                        #56
                        Has anyone tried these headers
                        http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
                        or these
                        http://cgi.ebay.com/ebaymotors/Racel...Q5fAccessories
                        It seems like the lower ones wouldbe easier to modify due to the two peice design. As far as the uppers go I am just curious if anyone thinks they will fit.
                        1989 332IS -S-Fiddy Four-Some weight removed.
                        5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
                        • hoveringuy
                          • Dec 2005
                          • 2745
                          #57
                          or these
                          I think the shorty headers are a drop-in replacement for the stock header, but I've heard that they don't do much.
                          "long tube or go home" seems to be the mantra...
                          besides the change in exhaust tone (or drone) I'd like to see some numbers on what they've done, dyno wise.
                          If I'm gonna go through the ass-pain I want to know it's worth it!
                          • rneedham1979
                            • Jul 2008
                            • 852
                            #58
                            I just bought this header... Hopefully my it can be installed with out issues...
                            http://cgi.ebay.com/ebaymotors/ws/eB...m=270392076676
                            Turbo E30
                            Roadkill 80lb 93 octane OBDI tune
                            BavSol Cylinder Head
                            Stock S50 in. cam Schrick ex. cam
                            Otis' tubular T4 manifold
                            Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
                            GT4094r w/Batmowheel Impeller
                            614whp@17.5psi, 100 Oct
                            690whp@21psi, 100 Oct
                            801whp@27psi, 110 URT
                            Old: 1/4 mile: 10.91@144.38 (636whp)
                            New: ?
                            http://www.youtube.com/watch?v=L_f7fUVqblI
                            • e30polak
                              • 6136
                              #59
                              That's what most of us run. just space the motor in between the passenger side motor mount and engine arm, with a 3/16th spacer/washer of some kind. And make sure to completely flatten the body-side heat shield on the engine side of the glove box to make sure that it doesn't rub/hold against the second header.
                              • rneedham1979
                                • Jul 2008
                                • 852
                                #60
                                sweet, thanks.
                                Turbo E30
                                New: ?
