Clutch Linkage Configuration
  • twright
    • 707
    I bought an unfinished E30/M50 swap car. I just got it running, but on the second drive, during a shift, the clutch pedal went to the floor and the clutch would not disengage.
    Disassembly revealed a bad slave cylinder. But, I also have some questions about the clutch linkage components. Here's what I have:
    E30 single mass flywheel
    E36 slave cylinder
    Getrag transmission
    E30 pressure plate
    E30 clutch disk
    Does this make sense? All of the components are E30, except for the slave cylinder. I tried an E30 slave cylinder, but the piston didn't "stroke" far enough. Only the E36 one would work. Is there something I didn't do right?
  • roguetoaster
    Biggus Tippus
    • 7819
    No, that does not make sense, although the E36 slave cylinder is much longer from mounting plate to end of the piston rod. Only thing I can think of is that you have a G250, which would require an E36 slave cyl to function normally.
    • e30austin
      • 15382
      The e36 slave cylinder would not bolt up to a Getrag 260, no matter how you spin it.
      If you had a Getrag 250, that would make a lot more sense, but I'm not sure how that kit would work in a Getrag 250.
      Pics will help to solve the mystery.
      • roguetoaster
        Biggus Tippus
        • 7819
        M20 stuff should in theory fit in a G250.
        All we really need is a pic of where the slave cyl mounts.
        • twright
          • 707
          Here's a couple of pictures. It all seems to working pretty well.
          • e30austin
            • 15382
            Looks like a Getrag 250 to me.
            • twright
              • 707
              Does this mean I have the correct slave cylinder? It seems to be working fine.
