Heater Fan Access
  • twright
    • 707
    Heater Fan Access
    I have finally started driving my 1988 325i (4 door sedan) M50 swapped vehicle. And I have noticed that the heater fan is really noisy, noisy enough that I might have to replace it. Am I going to have to drop the engine to get that fan motor out of there?
  • ForcedFirebird
    • Feb 2007
    • 8300
    Not really, but taking the intake manifold off will help, it's a tight fit in there with a 24v.
    john@m20guru.com
    Links:
    • D'Marco
      • Apr 2016
      • 2
      I was able to replace my blower motor fan with manifold on (s50 swapped) its a PITA but it can be done I suggest replacing the resistor that sits right below the fan its about 15$ on amazon while your in there.
      • ForcedFirebird
        • Feb 2007
        • 8300
        The manifold only takes a few minutes to pull. I often find it's actually faster overall to remove stuff in the way instead of working around it - but doing this for a living, have to streamline everything as much as possible.
        john@m20guru.com
        Links:
        • twright
          • 707
          Just reporting back in on what I found:
          I MIGHT have gotten the blower motor out of my 1988325i M50 swap if I had taken off the Intake Manifold. It would never have come out without removing the manifold.
          However, I was able to open the firewall cover and snake a small hose to the blower motor and put a drop of oil onto the bearings next to the fans. And: NO MORE SQUEAKING!
          That's all I really wanted. I didn't need to change the motor. I just needed to oil the old one.
