M52/G240/M20 flywheel swap
  • Shane6G72
    • Jan 2017
    • 3
    Sorry if this has been asked before but I'm wanting to upgrade the clutch in my m52 swapped 318is. My plan is to use a m20 flywheel, m42 spacer, m42 tob, e36 clutch, and starter gear from a m20. Will this work? Sent from my BBB100-1 using Tapatalk
  • twright
    • 707
    Make sure you also have the correct clutch slave cylinder. (I'm not sure which one that is.)
    • roguetoaster
      Biggus Tippus
      • 7830
      Sounds right, pretty sure that's what my S52 318ti had, although on second thought it was probably a G250.
      In your case I suspect an E30 slave is all that would fit as E36 ones are significantly different in shape/depth.
      • Shane6G72
        • Jan 2017
        • 3
        Sounds right, pretty sure that's what my S52 318ti had, although on second thought it was probably a G250. In your case I suspect an E30 slave is all that would fit as E36 ones are significantly different in shape/depth.
        Yeah, I thought about the g250 because it is apparently stronger but I don't like the angle change and welded shifter. I figure if the g240 fails I'll swap to a zf 5 speed. I'm currently running the stock g240 clutch and flywheel but it's too weak and slips under high load Sent from my BBB100-1 using Tapatalk
        • roguetoaster
          Biggus Tippus
          • 7830
          Realistically, you could probably just use an entire M20 clutch/FW setup. It's not like an M52 makes that much more power.
          • Shane6G72
            • Jan 2017
            • 3
            True true, but m52 clutch kits seem very cheap. The only issues is finding a m20 flywheel, they are impossible to source. I bought one awhile back but it turned out to be from a 325e so it's a dual mass... Sent from my BBB100-1 using Tapatalk
            • roguetoaster
              Biggus Tippus
              • 7830
              I have an M20 single mass with a used clutch/PP and a new TOB. PM if interested.
