Differential setup specs and sanity check
  • Rugbyfan
    • Jun 2011
    • 286
    Rebuilding my 3.46lsd to a 3 clutch. This will be for my ZF s52. These are the specs I’m seeing, can anyone confirm their accuracy?
    Crown Gear bolts-140ft lbs. I was going to torque first to 100, then to 140 and use loctite 272. New bolts and threads have been chased
    carrier flange bolts-17ft lbs. loctite 263
    input bearing rolling resistance 15-20in lbs
    carrier bearing rolling resistance 9-11in lbs
    backlash 0.0025”-0.0055”
    I still am looking for these values:
    lsd carrier cap torque (was going to use loctite 263)
    runout specs
    also what is the proper break-in procedure? I’ll be using motul fluid and keeping revs under 3k for 100mi. Do I need to swap fluid?
    "Broke into the wrong God damn rec room, didn't ya you bastard!"
  • Rugbyfan
    • Jun 2011
    • 286
    Well crap. My preload on my carrier bearings is too low. I’m assuming I need to decrease my shim thickness. Anyone have a source for shims? Ideally thinner?
    • TobyB
      • 5265
      Too low as in 7 in/lbs, or too low as in 'free play'?
      A little low wouldn't scare me enough to mess with it.
      Does the pattern look good?
      A diff shop can sell you aftermarket shims.
      t
      • Rugbyfan
        • Jun 2011
        • 286
        Too low as in 5in lbs (that’s probably too low, no?) I have not yet checked pattern as I do not have the ring gear installed.
        • Rugbyfan
          • Jun 2011
          • 286
          Hot damn, by using shims from my donor case (open 3.46) and mixing and matching with my working case (3.46lsd) I was able to get drag at 10in lbs
          • Rugbyfan
            • Jun 2011
            • 286
            My rebuilt 3.46 3 clutch is running well. ~700miles on it, no noise and no flakes in the fluid.
            I now have :
            A 2.93LSD complete diff
            A 3.46 complete diff
            can I use the LSD from the 2.93 to build a 3.46S? I remember reading something about <3.07 and >3.07 being an issue with LSD carriers but I cannot recall. Can anyone chime in?
            • Northern
              I like cupcakes & sh!tboxes
              • 5247
              I now have :
              Carrier cap (and I believe carrier as well) is different between the two.
              AFAIK, all other parts can interchange.
              Originally posted by priapism
              Originally posted by shameson
              • Rugbyfan
                • Jun 2011
                • 286
                Thanks! I knew I wasn’t crazy. I guess I’ll sell the 2.93lsd and 3.46 ring and pinion gears separate as it’s not worth the hassle.
