Electric Fan CFM
  • dele30
    • 116
    Electric Fan CFM
    Quick Question, I've been looking at a few different electric fans that I could run. What is the lowest CFM I would be able to run to keep it cool?
    I saw a few different ones just trying to get a base number before I buy.
    Also if you guys wouldn't mind posting up the links to the fans that you bought, need to see all my options, and the correct dimensions for the fan.
    I find that a 16" fan rated for 1600cfm is barely adequate in the south when driving in stop and go traffic. And that is with the stock M20B25 engine and no A/C. As a means of providing cooling for the engine bigger is definitely better.
      • 34844
      I would get a 2000cfm fan at least. if you get a curved blade fan it will be more efficient and quieter. 16" is a perfect fit too.
      • dele30
        • 116
        so 2000 CFM min. Then 16x16x? something slim right not trying to get a new fan to get crushed in a week.
        • dele30
          • 116
          take that back I'm going to mount it in the front. What works better a pusher or a puller.
          • lifeiskaos
            • 1709
            16" 2900cfm curved blade efan kept my turbo m20 cool in hot socal weather...
            • e30polak
              • 6136
              16" 3000 CFM Perma Cool does a great job for my s52 in stupid LA traffic. ;)
              INSTAGRAM: @UNDR8D_EMPIRE
                • 34844
                a puller, but any 2000+cfm 16" pusher is going to work just fine. It also gives more room to work in front of the motor.
                • Liam
                  • 753
                  Puller works better than a pusher but not by all that much.
                  The reason is that the radiator fins reduce the space for the air leaving the fan to continue the vortex that help keep up the velocity past the blade's trailing edge (not like you really needed to know this).
                  2000 CFM is enough except for conditions like this stupid (to an old man like me anyway) drifing thing where the engine is raging like hell and the ram air is all but non existent.
                  Oh, and 2 10" fans is what I'd use.
                  Last edited by Liam; 04-07-2009, 06:17 PM. Reason: Oh, and 2 10" fans is what I'd use.
                  I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                  • surebimmer
                    • Jan 2004
                    • 978
                    Anyone tried these: http://www.siliconeintakes.com/produ...b1b9b2fc88b460
                    • 416stroker
                      • May 2008
                      • 2448
                      whats the part number on your perma cool Im abut to hook up my ac and I know I'm gonna need more then 1600
                      Edit: N/M IM just gonna order a 3000 cfm pusher from summit
                      84 318I Delphin RIP
                      87 325IS delphin 24v Sold
                      89 325 Alpineweiss
                      • Dillinger
                        • 285
                        How much cfm do you loose by using a pusher instead of a puller?
                        • surebimmer
                          • Jan 2004
                          • 978
                          What's a stock aux fan rated at? That's what I run and have had no issues.
                          • etxxz
                            • Feb 2006
                            • 2085
                            i got that ebay 3200 CFM 16" ZIRGO fan strapped to the front of my radiator. My car has never overheated.. event at drift events which are pretty harsh on a car's cooling ability.
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
