s54 problems solved?
  • veet
    • 33
    electrical and ecu not my strong suit but for the members that know about this subject .Is it possible to run a s54 with s50 sensors, wiring harness and ecu? I am asking because i seen this on another site.
  • e30s52
    • Oct 2007
    • 5235
    Euro s50 yes.
    www.gutenparts.com
    • hugh jass
      • 2220
      what?
      you can't use the sensors from an obd1 s50 on an s54. everything is different. you need to integrate or defeat many of the systems on the s54 to get it to work in an e30.
      ______________________
      ex-Chief Operating Officer
      Blunt Tech Industries
      West Coast and Pacific Rim
      • e30s52
        • Oct 2007
        • 5235
        Coming from the euro s50 you can.
        www.gutenparts.com
        • e30s52
          • Oct 2007
          • 5235
          www.gutenparts.com
          • hugh jass
            • 2220
            please show me proof of this. the euro s50 is not much different than the us s50, both of which are very different from the s54. the s54 has dual vanos, etc. its not plug and play like the s50/s52
            • e30s52
              • Oct 2007
              • 5235
              Look on bimmerforums. The euro s50 has dual vanos. That is the only diffrence from the two that I see. It isnt plug and play but it is as close as you will get. I personaly hate bimmerforums so you can search for the thread and write up if you want.
              www.gutenparts.com
              • bimmerteck
                • 762
                No the euro S50 DME is missing entire busses that the S54 requires to operate. Not to mention all S54s shipped with EWS3.1.
                Show me an S54 running on any S50 DME euro or otherwise and I'll not only be impressed I might ask you some fun questions.
                I've had a little practice working out the S54 into other chassis problems and it is nowhere near as simple as any of the other common e30 swaps.
                Erik
                • e30s52
                  • Oct 2007
                  • 5235
                  I did the work for you.
                  Bimmerteck here is what the op said.
                  "instead i've used the euro s50b32 siemens mss50, with euro s50b32 engine harness. i also had to use a couple of s50 sensors.
                  i used this as it readily available here"
                  Personaly I would try this but due to the lack of funds and being in school kinda kills that plan.
                  www.gutenparts.com
                  • Jason89i
                    • Sep 2004
                    • 875
                    yes. you can use the mss50 s50b32 dme and harness to run the s54. It nothing new. the s54 is just an s50b32 w/ better flow characteristics. If i remeber correctly, all thats needed is the cam sensors, fuel rail and throttle conversion. I almost went that route, but found a standalone that can do the trick. cheers, jason
                    • Bimmerman325i
                      • 6854
                      Erik
                      Follow E30S52's link to bimmerforums, guy used all the euro stuff.
                      Have you swapped an S54 into an E30 and used the stock DME though? I would imagine that aside from the wiring PIA it would run better than using the euro stuff. I have heard rumors of shops selling DME tuning that allows the stock DME to be run in E36s without issue, but nothing for E30s. Personally, I would prefer that route, but if the euro stuff actually works, that may work better.
                      2017 Chevrolet SS, 6MT
                      95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                      98 M3/4/5 (stock)
                      • z31maniac
                        • 17566
                        This is getting me all hot and bothered.
                        www.gutenparts.com
                        • Bimmerman325i
                          • 6854
                          You and I both. If it is indeed possible to run stock DME or modded Euro S50 DME, and considering an S54 is aobut $4500 with all accessories and sometimes tranny too, this is a much better option than the S5x swaps. That is, as long as the electrical wizardry isn't outrageously expensive, it should provide better or equal hp/$ compared to an S5x swap.
                          98 M3/4/5 (stock)
                          • e30s52
                            • Oct 2007
                            • 5235
                            Yeah I know. This information just comes out right when I finnish my swap. Great :(
                            www.gutenparts.com
                            • Massive Lee
                              • Sep 2006
                              • 6785
                              The S54 has a much more complex engine management wiring than OBD1 S50-S52. It requires the e46 dash cluster, the ABS module (speed sensor) etc. which is why most S54 swaps use aftermarket engine management. The Euro S52 is only down 21hp, and is easier to wire.
                              massivebrakes.com
