s54
  • Pzary3233
    • Mar 2006
    • 39
    #46
    WOW, just amazing!
    Can't wait to see the final results of this combo!
    • 1mz
      • Jan 2009
      • 641
      #47
      jesus christ.
      http://l0st0n3.mybrute.com
      http://l0st-0n3.mybrute.com
      Work in progress: 1991 318i m50 swap
      Feedback thread :up:
      I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
      • Jason89i
        • Sep 2004
        • 875
        #48
        have had it on the track twice now. had a few quirks to work out. a code brown moment or two...... like a stuck throttle in the top of 4th going into turn 1. all in all, very pleased.
        still more to do, but im way too busy this summer. im just going to run it hard and put it away wet. i'll fix the rest this winter.
        one thing that had me stumped for days was the blue smoke on decelleration. (see video) it ended up being the power steering. yes, the power steering fluid was boiling, misting out the cap and into the filter. hard to believe i know. i underdrove the pulley, put a p.s. cooler on..... still had boiling fluid and blue smoke. between instructing and my session, i threw on a shorter belt and bypassed the p.s. pump (manual steering).... viola, zero smoke. go figure.
        video is the first day out..... John is giving chase with his s50's car. dont laugh at my early braking and coasting in the straights..... my confidence was a bit shaken with that whole stuck throttle business. cheers, jason
        blackhawk farms raceway 5-26-10bmw e30 s50 giving chase
        <object style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/slQHpLUaBDM"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/slQHpLUaBDM" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></object>
        • Spaz
          Crazy Canuck
          • 2276
          #49
          amazing, i'm jealous...next swap :)
          Cam .W '91 325is
          Spaz's 1991 Alpine White???? S52 Build Thread...
          • 7pilot
            • 475
            #50
            Excellent job on several fronts Jason.
            1, reincarnating the M3
            2, Updating the M3 chassis
            3, The engine and conversion.
            4, meeting the paradigms of the project.
            You Rule
            m
            • Schneller 3er
              • Oct 2004
              • 1720
              #51
              Looks good Jason. I'm still on a lookout for a ps cooler for you. As soon as I find one, I'll grab it, and let you know.
              Finally got mine on the road, but just like yours there's few things I need to iron out.
              Danny
              88 ///M3 - Zinno street/shop queen
              88 ///M3 - Henna Track rat (Sold)
              98 ///M3 hellrot - Sold
              89 Porsche 944 - dd
              95 E34 525it/pick up - P/U Project
              90 325is - track rat
              • Jason89i
                • Sep 2004
                • 875
                #52
                congrats on getting it on the road. What little details need to get ironed out? those little things can really add up.
                thanks for being on the lookout. my p.steering cooler is ghetto-tastic. its a 5' 3/8" brake line bent into a loop mounted below the radiator. Just got a z3 rack installed, will try it again in a couple weeks.
                cheers, jason
                • jahnaboi
                  • Oct 2006
                  • 1742
                  #53
                  Jason, you should change your sig picture. Highly deceiving. Great job on the swap btw. I plan on doing a s54 swap for the same person (s52/auto) if he finds a good enough deal. If not, his s52 auto + supercharger will be in order.
                  SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
                  • rThor432
                    • Feb 2007
                    • 3907
                    #54
                    Looking good Jason! Scary to hear about the throttle issue though.. That was a code brown moment indeed. Are you on street tires in the vid?
                    As for a solution for your PS problem, I'm sure Alex has mentioned his solution once or twice ;).
                    • dashboardmonkey
                      FUCK YOUR WAFFLES
                      • Jun 2008
                      • 6158
                      #55
                      damn sexy
                      -Andy
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        #56
                        Link to build thread?
                        '89 Alpine S52 with goodies
                        • 1craze30
                          • 1224
                          #57
                          a plug and play harness sounds very good. would make the wiring hassle a bit easier. what dme are you using?
                          • 240zs30
                            • 583
                            #58
                            I'm curious, since you moved the motor back 4inches, stick for the tranny move back as well? I'm doing a similar swap and I like the move the motor back solution as well. Nicely done!
                            • Jason89i
                              • Sep 2004
                              • 875
                              #59
                              Originally posted by jahnaboi
                              Jason, you should change your sig picture. Highly deceiving. .
                              takes too much time. really dont spend that much time around here anymore.
                              its not as easy as it looks. (see build thread.) but the results were very promising for a track car.
                              On a side note, just got an updated tune that was more comprehensive with the vanos movement. Mucho good. anxiously awaiting for the next track day. cheers, jason
                              • Schneller 3er
                                • Oct 2004
                                • 1720
                                #60
                                cheers, jason
                                I still need to get the front sway bar modified to fit around the headers, and also need to weld the stock oil cooler lines to mate them up with the euro lines at the top.
                                Otherwise, I'm pretty much set.
                                Danny
                                89 Porsche 944 - dd
