history
My 24v long term swap :) S54 I Love.
Originally posted by Wanganstyle View Post6mt gearboxes can run the gambit on pricing. 1.2-1.8k ya.
The 6mt also requires a very new style clutch. This is not cheap but allows you to fit a 335i turbo clutch.
modern clutch also moves the pilot bearing to a needle type inside the flywheel. Modern 22 spline 6 speed imput shaft design uses "involute" teeth pattern and is designed for more efficiency.
No need to change the pistons on m54, the original ones are made by mahle- aftermarket may be lower in quality. The original bmw mahle pistons also can take boost. Oem rods are also forged- don't waste your money and time unless you have some very specific build up in mind
The Bnb designs e30 6mt install kit is very inexpensive compared to buying the 6mt+clutch+driveshaft. Pm me if you find a reasonably priced local 6 speed gearbox and need one-
As for tranny i guess something like a 3.25lsd wouldnt be too bad for econ + highway pulls so i'll go with that for now. Nd as you said i'll look for a g250 cause i'll prob find b4 a zf320. I need to Frankenstein a drive shaft -__- know of any 1 piece shafts out there?
Just picked up a 4dr few days ago >=) can not wait haha.sigpic
Alpina B6 2.8/1 Project
http://www.r3vlimited.com/board/showthread.php?t=345025
Frankenstein Turbo Swap Thread [On Hold]
http://www.r3vlimited.com/board/showthread.php?t=255606
Originally posted by EulB30 View PostWell for now looks like im going 5, the forged pistions were just to make sure i'd be goof ccause i didnt want them to be the weak link on the R/A.. the m50 has ~90k m54 has ~150k.. so i might just the the m50 pistons on the m54 R/A n boost.
just run your motor as is; did you leak it down before you bought it/tore it apart?
IMO its Pointless to blow money to rebuild these pedestrian 6 cylinders; if it does not have ITB's its not worth BMW rebuild cost.
you need: 3.15 or 3.23 LSD. Modern z3 parts; not some rotten old garbage from junk e24/28 cars.
don't bother with G250; its not needed. Get a ZF sg320; its the same price.
any OEM e36M 5 speed driveshaft is plug and play for ZF sg320 5 speed + e30 body. Bolts right in.OBD1 M54/M52TU swap as a M50b25
Originally posted by Wanganstyle View Postyou need: 3.15 or 3.23 LSD. Modern z3 parts; not some rotten old garbage from junk e24/28 cars.
Torsen Z3 diffs are nicer, but harder to come by for a good price, with a good ratio.
2. I was under the impression that '95 driveshafts didn't work? I thought only '96 + 328 & M3 worked, as well as the e30 m3 driveshaft and '86-87 325e.Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Originally posted by e30polak View Post1. The better diff ratios were offered in e24/e28 cars. Most of those cars weren't driven as hard as the z3s/m-coupes/m-roadsters would have been. We've never had a problem with any of the old e24/e28/e30 diffs used in all the e30s we've built. Worst case scenario you get a noisy diff.
ONE missed point- the focal point actually; THE GEARS themselves.
the GEARS THEMSELVES changed for e36; the e36/7 Z3 gears themselves are more efficient, better items. Gear teeth design changed again in e92 era to be even more efficient. LSD unit in e36 era also changed; the cross shafts, spiders all evolved to be more efficient.
i.e. there are 3 different sets of 3.15 gears, early design, late design and M car specific with M14 hardware.
use 6 bolt 95 M3 driveshaft with e30 chassis center bearing, install 6 bolt flange on diff.Last edited by Wanganstyle; 06-06-2012, 01:44 PM.OBD1 M54/M52TU swap as a M50b25
Originally posted by Wanganstyle View Postregarding "good price" e30 crowd is the most cheap garbage crowd when it comes to important things like driveline. Who else would be running weird g260 m50 trans mount rigs?
use 6 bolt 95 M3 driveshaft with e30 chassis center bearing, install 6 bolt flange on diff.sigpic
Originally posted by Wanganstyle View Postjust run your motor as is; did you leak it down before you bought it/tore it apart?
And 3.23 i know i can find in e36's, 3.15? i might buy a M Roadster diff case though. ~$150sigpic
If you keep the 260, everything works as before, but with more power.
If you swap to the ZF, you have to re-think your rear end gear at the same time or very shortly afterward.
