My 24v long term swap :) S54 I Love.
  • Wanganstyle
    • 2828
    s54 got kicked to another car; this one got a HB 327S m20 + 6 speed
  • Wanganstyle
    • 2828
    history
    • Wanganstyle
      • 2828
      history
      • LJ851
        • 7919
        Are you going to put this fanciness back into an E36 or is it time to set up to an E30?
        Lorin
        The M30 is God's engine.
        • Wanganstyle
          • 2828
          An E30 will be getting full e36 front x conversion for Pnp rear sump action :)
          • LJ851
            • 7919
            ^ Wise choice. I look forward to seeing this run.
            Lorin
            • 325ix
              • Aug 2009
              • 7783
              Nice! I can't wait to see this thing all buttoned up. What are your plans for the rest of the car? Namely suspension and brakes.
              • samiam3356
                • Jul 2009
                • 1901
                Sub'd for s54 madness! Hope you document it well.
                Originally posted by Roysneon
                $5 shipped?
                Originally posted by MarkD
                You are a strange dude, I'n not answering any more posts from you.
                • z31maniac
                  • 17566
                  Interesting, looking forward to seeing your progress on this one!
                  www.gutenparts.com
                  • Wanganstyle
                    • 2828
                    Z3m/ e36m everything?
                    E46m brakes also could work :) the 05/06 fronts are CSL spec 345mm; 18" rims would be needed (and I do have volks that can come off the e36M.
                    We will see how long this takes as S54 should take a while to complete building and setup engine management for :)
                    • e30polak
                      • 6136
                      If you plan to track it, why not go with better coated rod bearings? Also, will you be swapping to ARP rod bolts?
                      INSTAGRAM: @UNDR8D_EMPIRE
                      • brian52555
                        • 425
                        Excited to see this at the shop... subscribed
                        • hoveringuy
                          • Dec 2005
                          • 2751
                          Subscribed. Please take lots of pictures and document this!
                          Which EMS are you using?
                          • gobuffs
                            • Dec 2004
                            • 513
                            I won't track another S54 without upgrading the rod bolts and bearings. The mains were done for peace of mind.
                            I had the same question.
                            • ACHTUNG
                              • May 2005
                              • 2397
                              Wangan...you have style.
                              1989 US E30 Cammed S52
                              Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
