S54 Swap Modifications Available
  • TinyT
    • Jan 2011
    • 152
    Hey guys, I wanted to move this over here because I started these swaps for S54's originally but the thread is in another section. I offer a modification service for your S54 pan and E30 subframe. The swap was designed using AKG 24v swap mounts. The modifications to the drivers side sump differ depending on the style of pan. I can make the mounts on the subframe for an E30 rack or E36 M3/Z rack.
    I will have a website up soon.
    Here are some pictures of the swap installed, these pictures have the simpler style pan with a side drain plug and E30 rack installed.
    Thanks for looking! Contact information is in my signature.
  • Wanganstyle
    • 2828
    do you have a solution for the U joint for e36/e46/e82 rack into e30 chassis? current solutions are so ugly; but I really want the 2.6 L-L rack
    • GK-E30M3
      • Apr 2008
      • 816
      Dose the Oil Pan on s50 or s52 have to be modified or only s54s
      and what the price to do the Subframe
      Chris
      • Andrew325is
        • Jan 2008
        • 1207
        Hey that's cool. Ive heard about custom subframes so the s54 pan can be used but I didn't know the pan still needs modding. Do you have a way to use an unmodded pan?
        Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
        • M3 Ryan
          Site Sponsor
          • 2298
          Chris
          Only modded for the dual sump S54 pan.
          I have this setup in my M3. Here are pics of my install, I had it powercoated black... Tyler does nice work!
          '88 M3.2 S54 Lachssilber/Black
          '07 335i Alpine/Black Sedan
          '12 X5 3.5i Alpine/Black
          iS Splitters For Sale, PM ME!
          • gobuffs
            • Dec 2004
            • 513
            Move the firewall.
            • e30polak
              • 6136
              For most people doing this swap, an e34 m50 front sump pan and pump, with a proper baffle is more than enough. Nice product nonetheless.
              INSTAGRAM: @UNDR8D_EMPIRE
              • rThor432
                • Feb 2007
                • 3907
                ^^But the E34 pan is no good for ground clearance. At least, that's my reason for going 2-sump.
                  • 34834
                  I might be too picky - but the S54 had oiling problems stock, and now you're replacing the pretty well designed oiling system with one meant for a vanilla engine and a 6500rpm redline, then expecting it to adequately supply what is basically a detuned race motor at 8000rpm.
                  it's a compromise some are willing to take (and they may have reasons/justifications), but I wouldn't do it personally...
                  • Wishno87
                    • 6025
                    +1 except I'm going single rear.
                    • Andrew325is
                      • Jan 2008
                      • 1207
                      I agree. Dual pickup is not necessary unless your gonna race on the track. It does add to coolness though. ;) Ground clearance is not an issue for me with the E34 pan. Parts of my exhaust and also my custom front sway bar are lower than the pan.
                      • rThor432
                        • Feb 2007
                        • 3907
                        ^^Single sump isn't an issue at the track either. I was at Daytona for a track day when Akard was running one of the race groups. I asked how the E34 pump was treating him (on a Euro S50) and he said it was solid and consistent. I've known a few other guys that ran the same setup with no oil pressure drop in race groups on sticky tires at VIR, CMP, Road Atlanta, Sebring etc-- all high stress tracks in one form or another. Justify either how you want, it's a preference thing really (per the data). Both are solutions to the same problem.
                        • Leo_328i
                          • 226
                          Originally posted by M3 Ryan
                          What front control arms are those? Looks awesome!
                          E82 racks fit E30?
                          Leo.
                          E30 318iS, E36 328i
                          • TinyT
                            • Jan 2011
                            • 152
                            Here are some recent subframe pictures.
                            Iv been doing most of them for E36 racks lately, no spacers needed!
                            • Wh33lhop
                              • 11705
                              AKGs.
                              paint sucks
