Will there be a S54 f.a.q. / how-to, like there is in the M/S50/2 section?
  • 240zs30
    • 583
    #31
    Originally posted by E30Strube
    For ease, I would recommend going with the modded pan/subframe that the guy here on R3v provides.
    If its the same I'm thinking of his name is Tyler The company I believe is Arcasylum. I think M3Ryan has it on his build thread for pics. I have this kit bolted to the the swap I'm selling. Sick welding and it appears to give more clearance for the lowered cars.
    • E30Strube
      • Jul 2008
      • 181
      #32
      I'm not running the E46 M3 PWM relay. I have a modded stock E46 ECU. Same one that Fred is using.
      Tyler is who did my subframe and pan also. The only issues I had with it were some slight clearance around the steering rack, in which I had to grind a bit of the subframe bracket for the rack. The second issue was with clearance to the bolts on the pan on the passenger side rear. There wasn't enough space to get the last bolt in. A stud welded to the pan would be the best fix there.
      Originally posted by nando
      do you have standalone? did you use the E46 M3 PWM relay?
      FWIW, the stock E46 M3 pump pretty much drops straight into the E30's FP carrier (late model, both 4 and 6 cyl). I'm not a fan of Walbro, but either way the stock M3 pump should work well, and you can get them pretty inexpensively.
      Even a new stock E30 pump would probably be good enough, but it might not live as long since the S54 runs on 5 bars of fuel pressure instead of 3. It would probably be worth researching when the turbo guys are maxing out the stock E30 pumps.
      I also think the PWM relay is worth keeping, should extend the pump's life as well as keeping things quieter.
      • E30Strube
        • Jul 2008
        • 181
        #33
        Another thing on the fuel pump. I tried using a Walbro intank and I couldn't get the pump mounted to the stock mount in a way that would both secure it and allow me to actually get it in the tank. I believe the carriers for the E30 M3 and the standard E30 in tank pump are different. The M3's doesn't allow for a simple way to mount anything.
        • flyboyx
          • 8371
          #34
          I really think the in tank fuel pump bracket is the same. I took the fuel pump out of my early m3 parts car And used it in a standard e30. I couldn't see any difference between the two.
          Chris, why are you adamantly opposed to hydro boost? It is a bit complicated to get hoses made but no worse than anything you are working on now. It provides lots of braking power and works great with abs.
          Gigitty Gigitty!!!!
            • 34839
            #35
            I think the stock booster can work, and work better. I know they've used the ix booster down at Castro's for an S54 swap. all they did was slide it over and modify the clevis. The driver's side where it would go is already going to be crowded and I don't want more weight up front.
            it may be a good solution for some but it's not for me.
            oh yeah, the doors on MSS54 have been blown wide open. The days of a $1500+ flash to get it working in an E30 are soon to be over.
            • FredK
              • 14759
              #36
              Any further information on this?
              • brian52555
                • 425
                #37
                +1 More info on MSS54 please!
                • 240zs30
                  • 583
                  #38
                  ^+ More info....
                  • DesertBMW
                    • Aug 2011
                    • 1028
                    #39
                    I can do MSS54 and MSS54HP programming for swaps, much cheaper than the cheapest competitor. Now that I have done the swap myself and figured out all what needs to be done to make it work right.
                    • nebulous123
                      • Jun 2011
                      • 923
                      #40
                      Can you give a ball park price? I am going to be getting into this wiring and such pretty soon. Will need a reprogram on the comp for deletes and such.
                      '84 325e - "Elizabeth"
                      '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                      • 89AlpineM3
                        • 548
                        #41
                        Go to him he's doing mine
