Hey Andrew for the S54 power button, can I use any button to wire into your harness, say a defrost button? I was thinking of getting one thats worn then stencil the word power on it and put it in the area that the hazards and the defrost are.
Andrew's DIY Guide for S54 Wiring Adapter Harnesses
This is a sticky topic.
Originally posted by Staszek View PostHey Andrew for the S54 power button, can I use any button to wire into your harness, say a defrost button? I was thinking of getting one thats worn then stencil the word power on it and put it in the area that the hazards and the defrost are.
Originally posted by g22 View PostI have an '89 325 with an OBDI M50. I'm going to an M52 and thinking of going OBDII. Can you make this harness?
Originally posted by Andrew325is View PostYou want to install a Start/Stop button? You can, but it's not necessary. Or do you mean Sport button? You could wire a defrost button as the sport button. I did that on my car. I include a generic switch as a placeholder.
Originally posted by Staszek View PostI want the sport button, so you wired in a defrost button, how did you do that, where did you get the generic switch from?
Originally posted by Bejoe16 View PostA buddy of mine wants to put a S52 in a 83' e24. Could you make a adapter for that swap?
Originally posted by Andrew325is View PostI can make an adapter for him, but he would need to send me his old C101. They are NLA from BMW for those cars.
Check Us out on Facebook
Full Product Line Tuning
The BMW dealer got back to me and they are not sure what the correct pins are for the E24/E28 C101 connector housing. The system does not show any corresponding pins. If they are the ones I found they are special order from Germany only. So if I order them it'll be a couple weeks before I know for sure.
Just an FYI, BMW increased the price of the USA S54/S62 fuel pump relay to $129.52 (list). Some online stores like autohausaz.com are still listing it at the old price, so act quick if you still need one for your S54 or S62 swap.Last edited by Andrew325is; 05-15-2016, 10:21 PM.
Plug and Play Wiring Harness Adapters for S54, M54, M52TU, & More
Originally posted by Andrew325is View PostThe BMW dealer got back to me and they are not sure what the correct pins are for the E24/E28 C101 connector housing. The system does not show any corresponding pins. If they are the ones I found they are special order from Germany only. So if I order them it'll be a couple weeks before I know for sure.
Thanks! I went and got to see the car and it's a bucket, I also didn't see any connector there. Not sure if missing or just what. I ended up talking him out of it. Thanks anyways!
