Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • Andrew325is
    • Jan 2008
    • 1212
    #316
    When shopping for an adapter harness for your swap you may be tempted to shop based on price, but there are other things to consider.
    Here’s a breakdown of the differences between Andrew’s harnesses from Harvey Racing and the competition.
    -Higher quality construction
    -Genuine BMW connectors (others often use 3rd party or homemade 3D printed connectors)
    -Metric high temperature wire imported from Europe that matches BMW OEM wire (others use cheaper AWG wire which does not properly match the connectors, the wrong sizes may not adequately handle circuits, and may not be high temperature which would be unsuitable for the engine bay.)
    -Better wire lengths (matched to original harnesses)
    -Premium Kester brand lead-free solder (3% silver) added to ring terminals and large connector pins to improve connections and seal out moisture.
    -Premium 3M brand heat-shrink and high quality braided sleeving to protect wires
    -Splashproof fuse holders protect important circuits (others may not include any fuses to protect circuits)
    -Labeled connectors and detailed instructions for easy installation
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • Andrew325is
      • Jan 2008
      • 1212
      #317
      Here are some discounts I’m offering in case that helps you.
      Save up to $500 off!
      Referral discount: $25 off next order for referral that results in additional sale and $25 off referred order. Can be accumulated up to 20 times. For example, 2 successful referrals results in $50 off next order and 20 successful referrals results in $500 off next order. Referrals can be made before first order as long as those orders are made prior. $25 max discount per referred order (2 or more referrals to the same person does not result in extra discounts). Discount does not permanently carry over (see repeat customer discount below).
      Repeat customer discount: $25 off each new order.
      Multiple order discount: $25 off each wiring harness when ordering 2 or more in same order.
      Discounts are not automatic and must be requested at time of order and does not apply to previous orders.
      Holiday Food Drive Sale! 🎉🍽️🦃
      Up to $100 off a wiring harness if you donate food to help those in need during the holidays.
      Donate $25 to $75 and receive matching discount + extra $25 off. Provide suitable proof of donation between 6 November 2025 and 31 December 2025 to receive discount.
      Examples of proof include:
      -Online donation receipt showing your name or email address with donation amount.
      -Photo of physical printed receipt from organisation with donation amount.
      -If you helped someone directly a photo of yourself with the person and a photo of the receipt or picture of food given.
      -A photo of yourself putting food in a donation bin with the value of food donated (food must be pictured)
      Donations can be made to a food bank, a store that is asking for food donations, a restaurant that provides free meals (receipt must show it is for a free meal), an organisation that provides holiday meals (e.g. Salvation Army Thanksgiving meal ticket), and direct & physical food donations.
      • ulmi
        • May 2020
        • 1
        #318
        Hi Andrew, just a little message to thank you, again, I did my swap 10 years ago with your harness, it's working perfectly fine :)
        • Andrew325is
          • Jan 2008
          • 1212
          #319
          That’s awesome! Your car looks sweet.
