Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • Staszek
    • 2533
    #166
    Hey Andrew for the S54 power button, can I use any button to wire into your harness, say a defrost button? I was thinking of getting one thats worn then stencil the word power on it and put it in the area that the hazards and the defrost are.
    • g22
      • 274
      #167
      I have an '89 325 with an OBDI M50. I'm going to an M52 and thinking of going OBDII. Can you make this harness?
      • Andrew325is
        • Jan 2008
        • 1202
        #168
        You want to install a Start/Stop button? You can, but it's not necessary. Or do you mean Sport button? You could wire a defrost button as the sport button. I did that on my car. I include a generic switch as a placeholder.
        Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
        • Andrew325is
          • Jan 2008
          • 1202
          #169
          Yes, I can make an OBDII M52 adapter.
          • Staszek
            • 2533
            #170
            I want the sport button, so you wired in a defrost button, how did you do that, where did you get the generic switch from?
            • Andrew325is
              • Jan 2008
              • 1202
              #171
              The wiring for the defrost switch is in the ETM for your car. You can also test which wires you need to use by using a multimeter. The switch I provide is a Carling on/off rocker switch. You can replace it with any switch you want or leave it the way it is.
              • Andrew325is
                • Jan 2008
                • 1202
                #172
                CAN controller for A/C, check engine light, etc now available pre-wired into the adapter harness. See original post for pictures and details.
                • gpeterson
                  • Aug 2012
                  • 119
                  #173
                  Looks nice with the CAN controller integrated!
                  • Bejoe16
                    • Jan 2014
                    • 91
                    #174
                    A buddy of mine wants to put a S52 in a 83' e24. Could you make a adapter for that swap?
                    • Andrew325is
                      • Jan 2008
                      • 1202
                      #175
                      I can make an adapter for him, but he would need to send me his old C101. They are NLA from BMW for those cars.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #176
                        the E28/24 C101s are still avail from bmw. Theyre the ones you get when you order the E30 square C101s...
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • Andrew325is
                          • Jan 2008
                          • 1202
                          #177
                          Yeah I think the connector housing is available, but I was pretty sure the pins, at least the small ones, are NLA. I think I may have found them though. I'll order one and find out. :) They're pretty expensive though. So if I can do this add $40 to the E30 price.
                          • Andrew325is
                            • Jan 2008
                            • 1202
                            #178
                            The BMW dealer got back to me and they are not sure what the correct pins are for the E24/E28 C101 connector housing. The system does not show any corresponding pins. If they are the ones I found they are special order from Germany only. So if I order them it'll be a couple weeks before I know for sure.
                            • Andrew325is
                              • Jan 2008
                              • 1202
                              #179
                              Just an FYI, BMW increased the price of the USA S54/S62 fuel pump relay to $129.52 (list). Some online stores like autohausaz.com are still listing it at the old price, so act quick if you still need one for your S54 or S62 swap.
                              • Bejoe16
                                • Jan 2014
                                • 91
                                #180
                                Plug and Play Wiring Harness Adapters for S54, M54, M52TU, & More
                                Thanks! I went and got to see the car and it's a bucket, I also didn't see any connector there. Not sure if missing or just what. I ended up talking him out of it. Thanks anyways!
