Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • Andrew325is
    • Jan 2008
    • 1203
    *Updated 9 July 2025* Order books have re-opened! :)
    Hello! My metric plug and play wiring adapter harnesses for S54 and S62 are available! Contact Andrew at harveyracingsales@gmail.com or on Facebook (https://www.facebook.com/share/16kSA...ibextid=wwXIfr) to place an order until I have the website back up (www.harvey-racing.com). Some harnesses in the common figurations are available for immediate shipment. No more lead times! Limited custom orders with a short lead time are also available. I've kept pricing the same for now even though my costs have increased. Prices are $575 for the standard harness and $725 with 20-pin diagnostic port. The 20-pin diagnostic port allows service reset and communication with body control modules.
    Adapter harnesses are planned for the following configurations:
    -S54 for E30 (with and without 20-pin diagnostic port)
    -S54 for E36 CANbus version (OBD1/Euro and OBD2, with and without 20-pin diagnostic port)
    -S62 for E30 (with and without 20-pin diagnostic port)
    -S62 for E36 CANbus version (OBD1/Euro and OBD2, with and without 20-pin diagnostic port)
    I will make a limited number of others such as S62 for E31 and M54 for E30 & E36.
    Features for S54 & S62 adapter harnesses:
    -OEM metric wire that matches the factory wiring on your BMW
    -Electronic accelerator pedal connector
    -Coolant temperature sensor connector (for instrument cluster gauge) (except S62 for E36 & E31)
    -Fuel pump relay wiring
    -Switch for sport mode (may be omitted on request)
    -OBD2 port for diagnostics (excluding OBD2 cars that already have an OBD2 port)
    -Power for ABS from DME relay (1990+ E30s)
    -Splashproof fuse holders
    -Power adapter cable for B+ junction
    -Labeled connectors and detailed instructions
    -Optional configuration: 20-pin diagnostic port for communication with body control modules (ABS, instrument cluster, etc).
    Examples of the adapter harnesses I make:
    CANbus S54 for OBD2 E36 with 20-pin diagnostic port:
    S62 for E30:
    S54 for E30 (this updated version puts fuel pump relay in stock location under M3 harness cover):
    S62 for E30 M3:
    S54 for OBD2 E36 with wires to connect to Z3M instrument cluster (this updated version puts fuel pump relay mounted in stock location on side of fuse box):
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
  • ZM Blue Devil
    • Dec 2006
    • 13836
    Bump for a good service.
    Levent
    %20levent@gutenparts.com
    Ladies:
    • Asbradley21
      • Jun 2008
      • 1938
      Email sent.
      S54B32 swap in progress. Status: Getting There
      • brian52555
        • 425
        Awesome service. What's the core charge if I don't have a harness to provide you with?
        • Andrew325is
          • Jan 2008
          • 1203
          I actually don't need a harness from you unless you'd like to have one adapted that will not reach your ECU mounting location. I can provide you with a new Z3 harness for $500. Slightly less for an E46 harness (I just found one for $279 although you can probably do better).
          • 89AlpineM3
            • 548
            Email sent bud, looking forward to it
            • Luke_M
              • Aug 2011
              • 258
              Email sent
              Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
              • GK-E30M3
                • Apr 2008
                • 816
                sweet i will in for s54 just need to organize some stuff
                • phreshkid
                  • 4655
                  I am really really keen to the idea of an aluminum block m54 in a 2002.
                  Hypothetically speaking, it should be easier?
                  • CrusherCurtis
                    • 2532
                    ^Yeah an all aluminum, shrick cammed, double vanos, m54 sounds like a better idea than a s50 for my vert.
                    • Andrew325is
                      • Jan 2008
                      • 1203
                      Just shipped another one. :)
                      • Fidhle007
                        I can fly, motherfucker
                        • Oct 2005
                        • 7209
                        This is awesome! Thanks! Someday I'll want one of these. Someday...
                        '89 325is S50 Track Montser
                        '04 X5 Daily/Tow Vehicle
                        http://www.avarestoration.com
                        http://www.myspace.com/brendanfiddle
                        Click here if you want to be my zombie slave...
                        http://www.youtube.com/user/Fidhle007
                        • kitsune
                          • Jul 2011
                          • 177
                          I want one! Might have to order one before you stop making them.
                          Funny thing is, I don't have an e30 yet :( Planning and still looking at E30M available and don't want to spend over $18k if I don't have too :( LOL
                          Mike
                          • Andrew325is
                            • Jan 2008
                            • 1203
                            I just shipped one to Spain. :)
                            • Andrew325is
                              • Jan 2008
                              • 1203
                              Sent one to Australia. :)
