Metric Plug and Play S54 and S62 Wiring Adapter Harnesses from Harvey Racing
This is a sticky topic.
  • Andrew325is
    • Jan 2008
    • 1212
    #46
    Just shipped an S54 adapter harness to Australia!
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • jrods
      • Feb 2011
      • 13
      #47
      Andrew i would like to ask you what are my options as far swaping
      an s54 into a e34 535i 1992. I know that this is not a common swap
      but that is the way i want to go. what could be done with wiring
      harness and ecu on both cars.
      Thank you for your help
      J rod
      • Andrew325is
        • Jan 2008
        • 1212
        #48
        J rod
        I can make a wiring harness adapter for you. The E34 wiring is like the E36. You need to use the stock S54 wiring harness and ECU.
        • disboifromja
          • Mar 2014
          • 1
          #49
          looking for a e30 swap harness s50 swap
          • Andrew325is
            • Jan 2008
            • 1212
            #50
            Sure, send me an email.
            • Andrew325is
              • Jan 2008
              • 1212
              #51
              Shipped an S54 adapter harness to Australia! :D
              • Andrew325is
                • Jan 2008
                • 1212
                #52
                Updated original post with new photo of the S50 wiring adapter.
                • Andrew325is
                  • Jan 2008
                  • 1212
                  #53
                  Just shipped an S54 harness to Maryland!
                  • N-Gen
                    • Mar 2013
                    • 97
                    #54
                    I cannot say enough good things about this guy.
                    I ordered an E30 M50 adapter and I have to say I'm impressed. The adapter looks like it was made by BMW themselves. Not only the item quality is superb, the communication is just as amazing. All the information regarding the car and the engine went through and he even supplied me with an extra diagram related to the A/C. He packed it, insured it and still came out cheaper than retailers. I feel safer when someone actually builds something around what I have other than just shoving an adapter into my face.
                    I cannot recommend Andrew enough! All I can do is bump the thread and spread the word :)
                    Unfortunately I cannot try it yet and probably not for some time seeing as my E30 is going through some major body work.
                    • MonkeyMadness
                      • 3251
                      #55
                      Email sent ;-)
                        • 34844
                        #56
                        where did you send it? I didn't get anything.
                        • Andrew325is
                          • Jan 2008
                          • 1212
                          #57
                          He sent it to me. :)
                          • alco
                            • Feb 2013
                            • 197
                            #58
                            Andrew325is, can you build a harness for M60 harness to 1987 325is built in 2/87. What is the cost?
                            Velocity Motor Works
                            1972 2002
                            1983 533is
                            1987 325is (Roxanne)
                            1988 M6
                            1989 M3
                            1989 325ix (Darth Maul)
                            Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...
                            • Andrew325is
                              • Jan 2008
                              • 1212
                              #59
                              Yes, it's the same as the M50 adapter. It's $200 shipped. I accept PayPal to eurotrash8@gmail.com.
                              • Andrew325is
                                • Jan 2008
                                • 1212
                                #60
                                I've just received feedback that the ring terminal I've been supplying for the starter terminal 30h (field terminal) on the S54 adapter harness is too small to fit over the bolt stud. My apologies! I will now supply a larger terminal. But for those who have the smaller one, you can connect it to any ground point instead of the starter. Or you can use a conical file to enlarge the hole or snip it off and crimp on a larger ring terminal.
