What am I missing
  • Bimmer_man
    • Jan 2013
    • 1477
    What am I missing
    I am gathering info and parts for an S54 swap and wnt to know if i have got everything if not please let me know or point me to where i can read up on what more is needed that i missed.
    S54 Engine Swap
    - Engine
    - VAC - S54 / S50B32 Euro / M54, Exhaust Air Valve Block Off Plate (for EGR delete)
    - E46 M3 fuel pressure regulator
    - ECU non smg
    - Wiring harness
    - ECU Tuning
    - VAC 24v Conversion brake booster
    - UUC Evo3 Shifter
    - UUC clutch line
    - E36 318i/325i clutch slave cylinder
    - UUC's red E36 M3 transmission mounts with enforcer cups
    - E36 M3 Transmission (zf)
    - S54 Z3 Clutch
    - E46 M3 Fuel pump
    - VAC - S54 Performance Coated Rod Bearing Set
    - Arrow Precision - S54 Con Rod, 139mm
    - E30 M3 Interment cluster
    - E36 M3 Mishimoto Radiator
    - Stuart Performance Water pump
    - E46 M3 Pedal
    - 3.25 LSD
    Im sure im missing a few things just let me know and I am not wanting alpha-N at this time so please dont suggest it.
    Float like a cadillac sting like a Bimmer!:)
  • bmwguy325is
    • May 2011
    • 1263
    01001001001000000111010001101000011010010110111001 10101100100000011110010110111101110101001000000110 11100110010101100101011001000010000001110100011010 00011010010111001100100000011000010111001100100000 01110111011001010110110001101100
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • sector6
      • 909
      first tell me what the code says in your sig...
      • Bimmer_man
        • Jan 2013
        • 1477
        That requires alpha-n tuning
        • Bimmer_man
          • Jan 2013
          • 1477
          The bmw e30 is the single greatest car in the world
          • 89AlpineM3
            • 548
            Why do you want to go with drive by wire? Keep the e throttle It's far better for the s54
            • e30s50dan
              • Nov 2008
              • 2076
              NASA
              BMWCCA member
              PCA member 25yrs
              1991 318IS slick top
              1997 M3 sedan
              2001 325CI DD
              “whoever turns the wheel the least, wins"
              • Bimmer_man
                • Jan 2013
                • 1477
                I like the feeling and a lot of people recommend it and i dont like the electronic throttle
                • Bimmer_man
                  • Jan 2013
                  • 1477
                  Originally posted by e30s50dan
                  That one i know lol
                  • Loupoz
                    • Feb 2012
                    • 166
                    Better than standard fuelpump
                    My 325I Mtech1 S54 Build
                      • 34844
                      what people?
                      the cable throttles are worse in every way imagineable. it's doable, but I wouldn't personally reccomend it. it would be better to retune the stock throttle curves if you don't like the way it responds. the US throttle tune is weak.
                      the cable conversion also costs like 3x as much.
                        • 34844
                        E46 M3 pump is almost a perfect fit into the late E30 pump carrier.
                        But, I do wonder if a new stock E30 pump would be fine. It might not like supplying 5 bars of pressure though..
                        • 89AlpineM3
                          • 548
                          Your also missing the redone oil pan, tiny T is an A+++++, and headers. Radiator etc. While the motor is out I would at least change out all the Rod Bearings and Rod bolts. Also look into the Vanos Unit....
                          • Bimmer_man
                            • Jan 2013
                            • 1477
                            Thank you vary much
                            • Bimmer_man
                              • Jan 2013
                              • 1477
                              I have talked to tinyT and ill be getting the custom subframe but i didnt know he made the headers and radiator. And as for the vanos im going to just do the maintenance on it till i decide to get a cam then ill be doing the VAC vanos delete. Ill look into the rods and bearings
                              PS: Thank you to everyone with this info i am trying to do as much research as possible on my own but there's some bits i get hung up on so thank you everyone
