What am I missing
  • Wh33lhop
    • 11705
    Originally posted by Titan_Omega
    I like the feeling and a lot of people recommend it and i dont like the electronic throttle
    First off, drive-by-wire IS electronic throttle. Bimmerworld's nomenclature is confusing.
    Second off, I would suggest driving an E46 M3 before writing off electronic throttle. It is not as bad as other DBW cars. Moreover, cable throttle conversions have been somewhat problematic. The S54 throttles were not meant to be cable-operated which presents a few issues with the conversion, most notably nonlinear return spring feel (I wouldn't take BW for their word on that). Honestly in this case it seems leaving the e-throttle system in place may be the simplest, most issue-free approach.
    paint sucks
      • 34844
      why VANOS delete? that's the best part of the S54. :(
      the main reason people do VANOS deletes is because their aftermarket computers can't run it.
      • Bimmer_man
        • Jan 2013
        • 1478
        I have driven the E46 m3 both the SMG and Manual. And I like the feel of the DBW. I will be keeping the original throttle stuff and i may change my mind. And i did drive both M3s in sport mode and standard. But seeing how a lot of people are suggesting the standard throttle set up so i may not go with DBW. On this project i base my decisions on others experiences.
        Float like a cadillac sting like a Bimmer!:)
        • Bimmer_man
          • Jan 2013
          • 1478
          Cause of the CAM i plan on getting.
          I plan on getting these cams 305/296 High Lift
          Duration: 280° / 272°, 12.5mm / 12.5mm Lift; 288° / 280°, 12.5mm / 12.5mm Lift; 304° / 296°, 12.5mm / 12.5mm Lift; 288° / 280°, 14mm / 14mm Lift (High); 304° / 296°, 14mm / 14mm Lift (High).
          • Wh33lhop
            • 11705
            http://store.vacmotorsports.com/schr...ets-p1337.aspx
            What purpose will this car serve, and how experienced are you regarding building, maintaining (and driving) cars?
            paint sucks
            • Bimmer_man
              • Jan 2013
              • 1478
              I have been driving cars for almost 7 years. I have raced a few one being a E46 M3. Thats when i fell in love with the S54. I maintain my own car and know all the maintenance that they need. As far as building I have a bit of experience. I should have mentioned this S54 will start out as a Street car but eventually turn into a weekend racer.
              As far as a S54 build up this is my first hens all the research into it.
              • FredK
                • 14762
                I agree with nando. The best thing about the S54 is the VANOS and its ability to gain huge area under the curve. You can get over 350 whp with regular-lift Schrick cams and a competent tuner.
                I don't know what your experience with power levels in an E30 are, but rest assured, having a car that is around 700 lbs lighter than an E46 M3 will make it rip with a stock S54, never mind one with 70 more whp.
                • Bimmer_man
                  • Jan 2013
                  • 1478
                  lol thank you ill do more research into this then thanks.
                  • DesertBMW
                    • Aug 2011
                    • 1042
                    That, and you won't be able to put tires wide enough to get traction anyway
                    • FredK
                      • 14762
                      Well, with high lift cams I doubt the torque would be increased a huge amount, though the high rpm power would be pretty beastly, so the tires probably won't be overwhelmed as long as you use some judgment. Just don't use crappy all seasons, otherwise you won't be doing the engine any justice.
                      It'd make for a fun track car, but you won't be able to open wheel race it competitively with any organization, as the engine would class you very high in CCA and NASA GTS.
                        • 34844
                        I don't think you'd want that cam anyway unless you did a high $$$$$$$ build with a stroker crank, sleeved bores, race gas compression and tune, carbon airbox, etc. etc.
                        basically to do a cam that agressive justice you'd have to dump obscene amounts of money on the engine. it would make a ton of power but it would be expensive, tough to live with, and probably not live all that long.
                        if you want to put it in a mostly stock motor a standard cam or "street" schrick makes more sense. All that cam will do otherwise is kill your bottom end with little gained up top, plus you have to remove VANOS so the torque curve would be even narrower. that's why it's a race cam. :)
                        • Andrew325is
                          • Jan 2008
                          • 1212
                          You are missing lots of things. My swap parts list has about 250 items. lol
                          Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
                          • e30s50dan
                            • Nov 2008
                            • 2076
                            Care to share that list!
                            NASA
                            BMWCCA member
                            PCA member 25yrs
                            1991 318IS slick top
                            1997 M3 sedan
                            2001 325CI DD
                            “whoever turns the wheel the least, wins"
                            • Bimmer_man
                              • Jan 2013
                              • 1478
                              Okay guys I edited what I need I am sure some things are missing still please advise on what else is needed. I am trying to do as much research as possible on this but I feel like im missing a lot of stuff.
                                • 34844
                                It makes no difference if the dme is SMG or not.
