S54 programing
    • 34827
    I should also add, it's not possible to make a MAF that functions well with an intake opening as large as the one on the CSL. If it were better BMW would have used it.
    MAF = emissions equipment, IMO :p
    • e30polak
      • 6136
      Sorry I got mixed up with the flap that a local vendor was creating to sync with the throttles. My mistake it acts as a muffler for the intake.
      And you're totally right on the MAF not working on a CSL box because of the massive opening. It was also proven that the Delage air box that retained a 3.5" opening because it used a MAF sensor and screen, added ZERO power over a proper air intake and the factory plenum.
      INSTAGRAM: @UNDR8D_EMPIRE
      • DesertBMW
        • Aug 2011
        • 1023
        CSL box still gets reduced down to 3" inch for the tube that sucks air from the front bumper cover then it has 2" (safety drain tube) if in case something gets stuck on the front bumper openening and for water drain. Only benefit of the CSL box is that it has much bigger filter element.
          • 34827
          yeah, you're wrong. it also has a lot more internal volume than the regular airbox. there's more to an airbox than the size of the opening.
          hemholtz resonance tuning. google. you. go. :D
          • e30polak
            • 6136
            WRONG!
            The volume of the airbox and the runner design are considerably different then the OEM airbox. The CSL intake is not just a pretty, over priced carbon fiber piece in the engine bay that sounds good.
            Do you really think BMW would've spent the time, resources and energy they did in creating the CSL package, if each part didn't benefit the car as a whole?
            The CSL intake plenum has the ability to flow higher CFMs then the OEM airbox, as do the higher flowing, better designed CSL headers and exhaust. The intake and exhaust were engineered to work directly with the custom profile camshafts. Finally the Alpha-N software, and faster MSS54HP DME.
            Also, what most people tend to forget, that the CSL intake set-up, especially when air is being drawn from the bumper opening, has the ability to suck in MUCH more air at speed due to the "ram-air effect" vs the factory configuration. This won't be seen on a dyno, where the air speed is constant, and the entire engineering behind the CSL set-up won't show it's true colors. I'll have to do some digging, but if I could find some data logging info on CFMs at speed between the 2 set-ups, then you would see the real world benefits of the CSL set-up.
            • DesertBMW
              • Aug 2011
              • 1023
              WRONG!
              Correct, the runner velocity stacks are slightly different, the air box does flow better, but argument is "how much better", does it justify spending 5k on one. And CSL is actualy not alpha N it is manifold apsolute sensor system.
              It is proven that CSL airbox alone brings only 1hp to the table and the cost is as much as good complete S54 engine. Ram air is minimal because it has no air scoop to collect air, very little pressure will be developed at 3 inch opening on the bumper.
              CSL has the same header as stock Euro M3 if I am not mistaken.
              BMW spends crazy money on stupid stuff that never makes it to market, they probably made that box when prototyping S54 engine so it only costs them to make one. not that they broke a bank over it
                • 34827
                it's blended speed density alpha-N. it's not pure alpha-N.
                • exdos
                  • May 2013
                  • 1
                  WRONG!
                  Do you know the internal volume of the CSL airbox? Any luck finding the results of the datalogging?
                  • nrubenstein
                    • 3148
                    I think that every single person in this thread agrees that it's a lot of money and that for most uses, the benefit is much more audible than felt. That said, once you hear a carbon airbox, it's very hard not to want one. The more aggressive the cams, the better the sound. (Ever hear Chuck Stickley's S54 in person? Quite possibly the best noise I've ever heard an engine make.)
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
