Possible M54 swap
  • -negrito-
    • 91
    Possible M54 swap
    I have a '88 vert that I plan on swapping engine later in the future.
    My brother gave me his '02 330i 5spd w/ Active Autowerke S/C
    A little history of the car. If I'm not mistaken this was one of the first 330s S/C'd by A.A. car was a full beast. After a couple of year S/C died and my brother left it in storage for a couple of years (he had e46 M3 Stg II S/C from active). I used to take out the car from time to time and the DME gets fried w/ 80k miles.
    All in all we changed 3 DMEs, change wiring harness, put the car back to stock same problem. My personal mechanic is a BMW Tech in Taiwan cant figure it out and the BMW Dealership here in Costa Rica tried a couple of times w/ same problem.
    Now my question is should I just take out the engine, tranny whatever accessories to swap in my e30 or should sell it to a BMW parts store that they offered me $6k for the car.
    Correct me if I'm wrong everything should bolt right in w/o any modification with the exception of the electronics. If I do it I would try to get the EWS flashed out or go MS3 (best route?)
    What would you guy suggest?
    TIA
  • Bimmer_man
    • Jan 2013
    • 1478
    You would need a few mods like either a custom sub frame and oil pan or replace the oil pump and pan cause the sub frame will not allow the m54 to fit. I you would need motor mounts drive shaft and a few other things surf around and do your reaserch I have been researching the s4 swap for over a month and still am working on the research.
    Float like a cadillac sting like a Bimmer!:)
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      Actually you can fab up a custom oil pickup and use a E34 M50 oil pan and it will fit fine. I think you are referring to the S54 swap.
      • -negrito-
        • 91
        Thanks for the input.
        I already have a e34 oil pan, sump, oil level sensor, dip stick and tube, and a new oil pan gasket. So I'll just need to fab up a pair of motor mounts? Do I need to modify the crossmember? Also, what do I need for driveshaft?
        Sorry if everything is answered but I see answers for the s54 not sure if would be the same.
        TIA
        • hoveringuy
          • Dec 2005
          • 2749
          I'm running an M54 swap for the past 3+ years now.
          Besides a few minor differences with the dipstick tube all of the mechanical stuff is exactly the same as any other M50/S50 swap.
          Same transmission options, exhaust, driveshafts, motor mounts, radiators, etc. The stuff that's different on the motor is up top, all of the mounting flanges are identical.
