S54 starter wiring - unloader relay?
    • 34839
    for those of you using an S54 starter - does it have a post to connect the wire for the unloader relay? if not, are you guys just grounding that wire?
  • FredK
    • 14759
    There is no 30h on the S54 starter, so I ran a wire from C101 pin 15 to T50. This is of course for a late model with a separate unloader circuit.
      • 34839
      ok, that makes sense!
      T50 is the main iggition/starter wire, correct?
      • FredK
        • 14759
        yup
          • 34839
          ok - so a simple pin 15 to pin 18 jumper. sweet. :)
          • Andrew325is
            • Jan 2008
            • 1212
            I connect C101 #15 (SW/GN) to the field terminal on the starter, which is terminal 30h on old starters so that's what I've labeled it as:
            You can see that on a starter that has the separate terminal, 30h is connected to the field terminal:
            Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
              • 34839
              another alternative is to use the M5x starter
              but, the harness has no C101 pin 15 or terminal to connect there - so I think jumping 18/15 should work fine too. :)
              • Andrew325is
                • Jan 2008
                • 1212
                Nope, the S54 harness does not have a wire to connect to it. That's why I include one in my wiring harness adapter. :)
                • FredK
                  • 14759
                  Of course not--30h / unloader at C101 pin 15 is an E30 function. To duplicate that function you may jump 18 to 15, hook pin 15 to T50, or to the field terminal. It achieves the same function--unloading of the electrical system at start, and powering major current draw systems.
                  Of course, if you have an early E30, you don't have to worry about this at all.
