Castro Motorsport: S54 E30 Engine Bay Porn
  • e30polak
    • 6136
    A couple recent 24v engine bays from Castro Motorsport
    INSTAGRAM: @UNDR8D_EMPIRE
  • carlb
    • Feb 2011
    • 359
    Awesome job guys!!! Loving the work Chris!
    1985 M635csi Black on Buffalo
    1985 535is Zinno on Black
    1985 M635csi White on Pacific Blue
    1988 M3 Lachssilber on Black (sold)
    1987 M3 Zinno on Black (totaled)
    • e30m3s54turbo
      • Jun 2010
      • 3292
      I like the Mtech with the Alpina B10's
      • jdirty
        • 346
        Such nice bays. I can't wait for the completion of that sedan.
        Btw what booster is on that white m3?
        • Lof8
          • Oct 2006
          • 2827
          You guys build some pretty stuff!
          S50'd
          Originally posted by TDE30
          What is this faggy shit I have happened upon?
          I can always live in a M3. Can't M3 a house.
          • 89AlpineM3
            • 548
            Wow beautiful, I neef to order one of your airboxes for my S54 swap. How do I order it ?
            • e304me
              • Feb 2006
              • 1374
              Man I wish I could legally do an s54 swap in cali...
              • unevolved
                • Nov 2011
                • 714
                Not trying to be facetious, but why can't you?
                1991 318i SOLD
                2003 325i SOLD
                Racecars and stuff.
                • e304me
                  • Feb 2006
                  • 1374
                  Because california. You have to pass a tailpipe sniff test, and also a visual test which I think is fucking stupid. There are ways around it, like finding a sketchy smog guy, but I would rather not have to do that. Right now my car has an aftermarket cat, but its ok because its registered in oregon. Not sure how long I can keep that up for.
                  • unevolved
                    • Nov 2011
                    • 714
                    I thought if it was a newer motor from the same manufacturer and met all emissions requirements, you could swap it in? I mean, that's what I remember from my Honda days.
                    1991 318i SOLD
                    2003 325i SOLD
                    Racecars and stuff.
                    • e30polak
                      • 6136
                      Technically you can pass emissions,/have it BAR certified, BUT it's very expensive.
                      The E46 M3 has a pretty involved EVAP system, which is the biggest obstacle. You would have to pull the gas tank from the E30 and make the EVAP system work as it would from the factory. It's a large unit that won't simply drop inside the e30 (or e36's) tank. Also, since the E46 M3 works off of CAN BUS, you have to use/make a can bus controller that will send the same signal for readiness on the DME, which is NOT easy.
                      Rule of thumb, it's not just having all the emissions equipment present in the car your swapping. You also need everything to work AS IT WOULD in the original car.
                        • 34844
                        I'm pretty sure that the EVAP system on the E46 doesn't use CAN? the pump is driven directly by the DME? is it the pressure sensor?
                        anyway, the swaps look great - I like the "stock" swaps best (I don't know, I don't see the point of a turbo S54 in an E30). Do guys sell that airbox? how much?
                        • unevolved
                          • Nov 2011
                          • 714
                          Damn, that sucks. I know it's for a reason, but still. Makes me appreciate Texas even more.
                          1991 318i SOLD
                          2003 325i SOLD
                          Racecars and stuff.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Have you done any flow tests on that airbox Mod? Specifically obviously cyls 5/6 since the box is chopped there?...
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • DER E30
                              • Sep 2013
                              • 2349
                              That grey one... Shiny...Oh wait, ALL of them!!! WOW!!!
                              -Christian
