S54 no start issue
  • said
    • Jul 2006
    • 61
    S54 no start issue
    Hi Guys!
    i have a swaped s54 into my e30. I've had troubles with the dme, flashing it, etc...
    finally, i bought a perfectly flashed dmd from frank smith, but my car only start when i spray fuel into the TB, then it runs perfect, idles great and keeps running!
    I have 1 bosch 044 pump which is priming on ignition and when cranking, my FPR gauge reads 5 bar when cranking, so there is fuel, but no injectors opening on start up....
    CPS is New and Cam sensors are new too...
    any idea on what could it be?
    thanks!
  • DesertBMW
    • Aug 2011
    • 1023
    That is EWS block. on mss54 it blocks the injectors only and it will run if you spray starting fluid. There is also relay only for injectors.
    • said
      • Jul 2006
      • 61
      Mmm... But the ecu was flashed to run on my e30.....
      ????? What can i do!!
      • DesertBMW
        • Aug 2011
        • 1023
        porque estas tan seguro
          • 34827
          did frank give you a cable for flashing?
          • said
            • Jul 2006
            • 61
            he did... but i preferred that he flashed the ECU on site and the shipped it to me... since i was in peru, i though that was the best way..
              • 34827
              if you have a cable he should be able to update it remotely. I doubt he forgot to turn off EWS, but maybe it wasn't communicated properly.
              • said
                • Jul 2006
                • 61
                I do have a cable....
                Ill see what he says, if he tested the ecu before shipping, then i dont know what to say...
                  • 34827
                  just ask him if the EWS was turned of and if not I'm sure he can fix it
                  • said
                    • Jul 2006
                    • 61
                    just noticed that if i turn ignition off and on again, sometimes it will start...
                    so its not EWS for sure... but there something there, it should start ALWAYS, not randomly
                    any ideas?
                    • The Dark Side of Will
                      • Jun 2010
                      • 2796
                      Are you saying that it starts with starting fluid, but then keeps running on its own?
                        • 34827
                        any ideas?
                        it's doing that because it's priming the fuel pump and injectors.
                        it would not run on it's own if it was EWS though, I missed that.
                        • said
                          • Jul 2006
                          • 61
                          So... still having start issues... car will start after turning the ignition about 5 times.. weird huh?
                          this time im suspecting on the clutch switch, since my car is a pure race one, i don't have any switch down there, and i know m3's needs to press the clutch for the engine to start... my starter turns, since its wired directly, but should i feed the clutch signal on the ECU? now.. its ground or 12v? can't really understand the diagrams!
                          thanks for the help!
                            • 34827
                            you don't need a clutch switch for an S54 swap. the only way it would stop the car from starting is if you'd installed the entire EWS system.
