Can the S54 mount to the g260 without any major mods?
  • ali123
    • May 2014
    • 54
    Hey guys I've secured a not so bad deal for an s54. But it's just of the engine. I'm guessing I will have to buy the ecu separately and I was wondering if I can use the G260 transmission or do I need to buy the ZF?
    Thank you
    • 34839
    the getrag bolts up directly but the engine will be at the wrong angle. you want a ZF at the very least, preferably a 6 speed but I understand the cost. the ZF 5 speed has similar gearing to the Getrag 420 except it has no 6th gear for cruising.
    I have an MSS54HP I can sell, I can flash it too.
    • ali123
      • May 2014
      • 54
      Ok I can probably find a junkyard with the 5 speed. By flashing it do you mean to remove EWS? If so please pm me. We're pretty much next door neighbors distance wise lol.
      Thanks
        • 34839
        oh yeah I just noticed that.
        • 328ijunkie
          • May 2007
          • 3961
          itll bolt up and hold the power. Stock clutches wont handle the revs though. Pressure plate will explode.
          Check Us out on Facebook
          Full Product Line Tuning
