S54 swap fuel delivery options.
  • WannaBe30
    • Feb 2013
    • 295
    So I know about using the factory s54 fuel pump, fuel pressure regulator and fuel filter.
    I saw on someone's build thread they used another type of fuel pump but for the life of me I can't find that thread...
    I think it started with a "d" brand name
    What other or better options for fuel pump are there.
  • FredK
    • 14763
    That was Andrew. He used a Deatschwerks DW300.
    • WannaBe30
      • Feb 2013
      • 295
      Thank you for some reason I though he used a factory one
      • E30Strube
        • Jul 2008
        • 181
        I kept the stock in-tank unit and replaced the in-line unit with a Walbro. Stock regulator and one of the small in-line filters.
        • WannaBe30
          • Feb 2013
          • 295
          You mean the stock e46 m3 in take unit? And added another fuel pump? Or filter not sure what you mean e30strube
          Ill already ordered a deatschwerks
          • E30Strube
            • Jul 2008
            • 181
            The stock E30 in-tank pump.
            It is just acting as a puller to get fuel out of the tank and to the in-line pump. I had an M3, so it had two pumps stock. I assume it's the same on a standard E30. I originally wanted to change the intank pump to a Walbro and delete the inline pump, but the Walbro wouldn't fit into the opening to the tank.
            • WannaBe30
              • Feb 2013
              • 295
              Non m has one in tank pump
              • Andy Mechnic
                • Jan 2015
                • 117
                I'm thinking the way you went is the easiest upgrade WannaBe30... I'll be doing something similar with my swap.
                  • 34844
                  why not just use the E46 pump? it's simple, effective and cheap.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Only late models. The m3 used early model setup that has 2 pumps, a low pressure high volume lifter pump in the tank, external inline high pressure pump to the engine. Everything (except m3) after 1988 used a single pump.
                    john@m20guru.com
                    Links:
                    • WannaBe30
                      • Feb 2013
                      • 295
                      Good info, I forgot about that i knew the earlys did have something different about their fuel system
                      • WannaBe30
                        • Feb 2013
                        • 295
                        Because even new with my dealer cost it cost more and I didn't want to buy a used one. But also from what I've heard these are more dependable than the stock one.
                        I receive it too! Very fast shipping. I'll post some pix on my build thread
                        • M3PO
                          • May 2012
                          • 537
                          Am I correct in assuming that the stock Eta twin pump setup can't supply enough pressure for an S54? I need to replace the external inline pump with a Bosch 044 or similar?
                            • 34844
                            Bosh 044 is overkill for a non-turbo S54
