E30 S54 Swap AC signal input to DME
  • Staszek
    • 2533
    Does it work?
    • gpeterson
      • Aug 2012
      • 119
      Originally posted by Staszek
      Does it work?
      Yes - only issue I had was one of the hose crimps let loose with a bang. The hydraulic shop seemed a bit confused and I'll probably buy the Mastercool crimper and re-do my hoses.
      I'm planning on producing more of the CAN interface boards and selling them. I could support M/S52 compressor with pressure switch or S54 compressor with pressure sensor.
      • diesekte
        • Sep 2013
        • 417
        If you make a package with the stuff drilled/tapped/welded with the CAN board count me in. I can supply the pressure switches and the hose end/fitting that allen bolts onto the S54 compressor etc obviously
        • Staszek
          • 2533
          Yes, if you make this I will purchase! So you are saying you you can use either S54 or S52 compressor?
          • R3Z3N
            • Jan 2011
            • 3056
            I would also purchase for either S52 or S54 compressor, however I would prefer to use the S54 compressor.
            • gpeterson
              • Aug 2012
              • 119
              I'll definitely be selling the CAN boards, not sure about the pressure sensor adapter or lines. My S54 is in an E36, not E30. Lines were a bit of a pain as I had to order a few different ones from salvage E46 cars and cut/bend/weld then have them crimped.
              Either compressor will work. I wanted to use the S54 compressor because it is variable displacement (should reduce/eliminate cycling) and I got one with my motor.
              The pressure switch vs pressure sensor does affect the way the DME compensates for load. It can do a better job if it uses the pressure sensor. It will also regulate the aux fan speed based on pressure and radiator outlet temp.
              My latest board prototype with work with the pressure switch or sensor. Compressor doesn't matter. It will also drive a check engine light. I hope to have production-ready batch of them completed in the spring.
              • Staszek
                • 2533
                Awesome perfect timing!
                • mpwrcpe
                  • 83
                  Count me in as well.
                  -Dave
                  _________________
                  -15 Pure White/Anthracite VW Touareg TDI Lux
                  -95 Avus M3 S54B32 Race car
                  -72 Chamonix 2002 (New project)
                  -90 Calypso 325ic (70K Original miles)
                  -00 M Coupe - Sadly sold
                  -97 328is - Sold
                  -90 Sterling 325is - Sold
                  -73 Taiga 2002 - Sold
                  • iliad
                    • 474
                    • mpwrcpe
                      • 83
                      Any update? I could actually use this now.
                      -Dave
                      _________________
                      -97 328is - Sold
                      • gpeterson
                        • Aug 2012
                        • 119
                        Not yet - I figured I'd have until spring to make them production-ready. Are you still using A/C in Arizona this time of year or just looking for a functional CEL right now?
                        I just noticed your username/location and realized I purchased an item from you in bf.c last week. Funny.
                        • mpwrcpe
                          • 83
                          Ha hey Garry! You should see the airbox tomorrow depending on the weather (it's snowing here now).
                          I'm getting ready to tie up the wiring on my S54 swap. I had the CAN wiring added to my swap adapter harness to make this addition very simple. I'm mainly interested in the CEL function right now, but I may put the AC back in depending on how much track time the car actually sees. I have enough wiring in place to stick this unit inside near the glove box or anywhere else really. If you can make something up that would be awesome!
                          -Dave
                          _________________
                          -97 328is - Sold
                          • gpeterson
                            • Aug 2012
                            • 119
                            Ok, I can get something together for you after the holidays. It won't be the same as the production ones I'm working on but will be functionally equivalent.
                            Did you already get your DME flashed?
                            • mpwrcpe
                              • 83
                              Frank Smith (TTFS) has the DME now. That would be awesome if you can throw something together!
                              Sent from my flux capacitor.
                              -Dave
                              _________________
                              -97 328is - Sold
                              • cek
                                • Jan 2014
                                • 85
                                Subscribed. I'm interested as well.
                                Vlad: '87 535is │ Maytag: '87 528e │ '88 911 │ Project Minerva - S54 E28
