Where is everyone mounting their s54 swap ecu?
  • diesekte
    • Sep 2013
    • 417
    Pics please. I'll be using the e46 m3 engine harness so I can't quite make it to the glove box
  • diesekte
    • Sep 2013
    • 417
    anyone?
    • BMWfanz
      • Dec 2013
      • 46
      Used e46 M3 wiring loom, ECU in glovebox, just cuted and extended MAF connector.
      • jink0619
        • 808
        Huh? so u extended every wire on the e46m harness to reach glovebox? Cause only the Zs54 harness will let you mount it there.
        E30love
        • BMWfanz
          • Dec 2013
          • 46
          I've just extended only MAF connector, other wiring reach glovebox easily, just need to reverse wiring in the plastic box on engine block.
          • diesekte
            • Sep 2013
            • 417
            BMWfanz - any pictures of what you mean?
            I would also like to mount in the glovebox, but my swap is already way over budget, and I can't afford another ~500 for the z3m harness
            • BMWfanz
              • Dec 2013
              • 46
              Bolt the plastic box on engine block,and you will guess what to do. You need to reverse rubber part of wire with all connectors to the backside and all connectors to ecu will easily reach glovebox except MAF
              • jink0619
                • 808
                Ummm I think what you have is a harness from the Zs54 sir cause there's no way the e46m harness easily reaches the glovebox.
                E30love
                • BMWfanz
                  • Dec 2013
                  • 46
                  From Z3M s54 nothing is needed to extend. I've used M3 E46 wiring from totaled M3 and i have no idea why you thinking this way. My car is running perfect on E46 wire
                  • jink0619
                    • 808
                    If so then your the only person that has done it, got any pics?
                    E30love
                    • BMWfanz
                      • Dec 2013
                      • 46
                      • anaphe
                        • Jan 2010
                        • 56
                        I extended mine and mounted it where the glovebox was
                        AK
                        • Andrew325is
                          • Jan 2008
                          • 1210
                          That's very clever BMWfanz. :up:
                          Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
                          • BMWfanz
                            • Dec 2013
                            • 46
                            Thanks, Andrew!) I would prefer your plug and play wire, but previous owner of my car ruined the harness , so there was no idea how to do it except custom work)
                            • jink0619
                              • 808
                              Fantastic! you won't be the only one anymore lol
                              E30love
