M54B30 rod questions
  • Bimmer_man
    • Jan 2013
    • 1478
    I figured this may be the best place to ask a few questions on the M54B30 rods. Just the rods. Im getting custom pistons. So i have herd conflicting information i would like to have cleared up.
    Are M54B30 rods forged or cast?
    And how much power can the rods themselves handle? Im looking for a max number it the number is too low then ill spend the extra 1k for better rods.
    Please let me know guys.
    Float like a cadillac sting like a Bimmer!:)
  • DesertBMW
    • Aug 2011
    • 1042
    M54B30 rods are the same as S52b32 rods. Same part number. These rods can handle 1000hp no problem. Rods rarely fail from too much power, they fail do to overreving and detonation
    • Bimmer_man
      • Jan 2013
      • 1478
      thanks man i appreciate the quick response. I was hoping for that. im not going to try for 1000HP but thats good to know.
      • digger
        • Nov 2005
        • 6198
        as said rods don't fail because of hp, its rpm or cylinder pressure. what engine specs?
        • Bimmer_man
          • Jan 2013
          • 1478
          sending you a PM digger.
          • digger
            • Nov 2005
            • 6198
            you'll want better rods than stock, will probably make bags of torque
            • Bimmer_man
              • Jan 2013
              • 1478
              dern, okay if that was the case I was looking at Arrow precision. what are your thoughts?
              • digger
                • Nov 2005
                • 6198
                arrow are a good brand
                • 328ijunkie
                  • May 2007
                  • 3961
                  Depending on your power goals, stock rods are fine.
                  Check Us out on Facebook
                  Full Product Line Tuning
                    • 34844
                    all rods are forged.
