question about cost on s54 swap
  • pvrse
    • Dec 2015
    • 141
    If I have a complete s54 engine, how much am I looking at roughly for parts and labor? An estimate would be nice from someone who has done it before!
  • mcm185
    • May 2013
    • 132
    8-10k + the engine
    • pvrse
      • Dec 2015
      • 141
      dang.. what makes it so much more expensive after the engine?
      • The Dark Side of Will
        • Jun 2010
        • 2796
        Oil pan, crossmember, wiring, exhaust fab, DME tuning, transmission & clutch, driveshaft if using the 420G, intake plumbing, cooling system, oil system... Anything else?
        • mcm185
          • May 2013
          • 132
          Labor, doing it right. You can go ahead and estimate less but you'll end up spending that or more. Just the wiring harness + DME flash you're looking at 1.5-2k. Probably 30-40 hours in labor to get it done right.
          • R3Z3N
            • Jan 2011
            • 3056
            Also acquiring parts for S54 swap. I bought from A 2006 Z4M, so cost will be a little higher, still AC, ECU flash+tune, custom exhaust, custom trans brace and other odds and ends are needed. I previously had an S52 installed so some parts transfer....not much.
            So far here is what I have bought, no labor yet: A far amount wont be needed if you get the engine from an M3 instead of Z4M.
            • george graves
              • 20003
              $2k DME flash - damn.
              Originally posted by Matt-B
              • diesekte
                • Sep 2013
                • 417
                I did it for about 10 total, and rebuilt the engine in the process. Not for the faint of heart or light of wallet
                • pvrse
                  • Dec 2015
                  • 141
                  wow, thanks guys for the solid info. So I'm assuming around 10-12k depending on what I can get it all for.
                  • Staszek
                    • 2533
                    Its funny I was just adding up what I bought and I am close to $10k without the labor. I think $10k is a good estimate depending on what you do with the car. There are different methods that can save some money, I have not seemed to choose any of them lol.
                    • R3Z3N
                      • Jan 2011
                      • 3056
                      Crazy high quote for that unless it includes remote dyno time which I will be doing, but still paying far less.
                      • gpeterson
                        • Aug 2012
                        • 119
                        You beat me to it. All of the info is out there if someone wants to learn and do it for free. If not, I'll do it for $100.
                        • E30.WLA
                          • 64
                          I'm taking on the challenge to make this swap under 6k. Prices of s54's are going down. I already have a standalone setup.:hitler:
                          • DesertBMW
                            • Aug 2011
                            • 1042
                            Benefit vs. the cost
                            It is true. Properly swapped S54 is expensive. Now you got to consider if it is all worth it.
                            I personally don't think it is worth putting S54 into E30 for $10k
                            • FredK
                              • 14762
                              You can certainly do a swap for under 6K if you get the engine cheaply enough, and you get creative with some of the parts.
