S54 E30 redlines at ~5800
  • Rabee99
    • Apr 2022
    • 3
    Mss54hp vss issue
    • Northern
      I like cupcakes & sh!tboxes
      • 5248
      connect your VSS
      Originally posted by priapism
      Originally posted by shameson
      • Rabee99
        • Apr 2022
        • 3
        Originally posted by Northern
        connect your VSS
        I want to delete it from ecu engine swapped to e36 car for drift doesn't need those errors
        • R3Z3N
          • Jan 2011
          • 3056
          However the ECU needs it.... connect it, I have a stickied thread on how to wire and set VSS (at least for running via diff sensor.) The ECU either needs signal from ABS or via direct. There is no other option programmed into the ECU. Honestly though, if you are a drifter/grifter, I recommend using Vipec/VEMS some other ECU without all the safety features built in for a smog compliant car.
