I am doing an M54 swap with the 6 speed from the e46 330i. I shortened the shift carrier (about an inch), and mounted it up using the e90 rear mount with a modified Arc Asylum trans mount. So far so good...
It is mentioned that the e36 M3 auto driveshaft fits for this, but that is not correct. While it does mount properly, the splines of the two halves only engage about an inch, which is not good enough for spirited driving. Has anyone else done this swap? Considering it is much more difficult to lengthen a driveshaft, I am wondering if anyone has a combo that works out of the box, or needs shortening to work. Jordan mentioned in his build he used a Z4 front, M3 rear. I am waiting to hear from him on the specifics. Anyway, looking for more info, and posting this to help others down the same path.
Thanks,
Chris
Thanks,
Chris
