So I am looking for a little bit a help with the wiring. I’ve got it all hooked up with Andrews harness and it cranks but I am getting no fuel pump signal I have a brand new fuel pump or EKP module. I noticed when I turn the car on or try and crank the car the outputs on the module never change so never signals the fuel pump I also back probed all the way through to the fuse in the fuse never sees signal either fuel pump isn’t being actuated it all. Where should I start looking for issues advice please.
S54 Crank but no fuel help please?
Figured it out. The main power relay wasnt switching. Cleaned everything and boom it fired up. It was loud as hell. I learned the hard way that my 100 mile old throwout is dead. Engine runs tranny is coming out.1989 332IS -S-Fiddy Four-Some weight removed.
5 lug E36 M3 Brakes Coilovers and LTW's and No ABS. -
Oh awesome. I just sent you a message on how to check the fuel pump relay wiring. That could still be helpful in the future.Comment
